Old 01-14-2016, 04:53 PM   #1
Jimsue's Avatar
Hard wired EMS 50 C surge protector
Greetings to all from here in snowy Western Michigan. I just bought the installable or the hardwired Progressive Industries EMS HW 50 C and M looking at options for installation.
Someone mentioned that old coot somehow installed his in the same location but apparently he installed a plug on the device and was able to plug it in so to speak for portability.
I too would be interested in that type of installation if I could get a little more information on how or if it was done. I would like to be able to easily remove my hardwired EMS surge protector in the event that I decide to upgrade my recreational vehicle. To be able to plug or unplug it from inside the trailer would be ideal. The thing is I guess I would have to install to mail and two female 50 amp receptacles in order to plug or unplug the device. Or would it be possible to install some sort of junction box behind the fuse box in order to wire search protector to the fuse panel?
2013 Palomino Sabre BKOK 31
F350 Powerstroke Lariat, 2015
Demco Autoslide Hitch
PI Hardwired EMS HW50c
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
andersen ultimate 5th wheel hitch
Renogy Solar Suitcase
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 01-14-2016, 05:29 PM   #2
Jimsue's Avatar
Oops...Autocorrected again! That's SURGE not " search" protector , though a search protector might come in handy when crossing the border 😜
2013 Sabre BKOK 31
Old 01-14-2016, 05:36 PM   #3
HONDAMAN174's Avatar
You are correct with the plugs. That's how some install it. For me, it was just as easy to pull the cord in and connect to the PI then run another Romex back to junction box.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 01-14-2016, 06:30 PM   #4
Kenny kustom's Avatar
I would have to agree.
That seems to be a lot of cost ( plugs and receptacles) and hassle.. For what is likely going to be in there for a few years.
Just hard wire, when you sell, either leave it, or reconnect the shore to the panel. Wouldn't take more than 20 mins.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-14-2016, 06:36 PM   #5
fonzie's Avatar
Here's one installation of a 30 amps but would be similar for 50 amps...
http://www.forestriverforums.com/for...r-66460-6.html
Fonzie
Old 01-14-2016, 06:47 PM   #6
davel1971's Avatar
2 pairs of 50 amp plugs would be expensive. If you ever need to take it out in future, you could always reconnect wires using a junction box
David & Lynn
Old 01-14-2016, 07:47 PM   #7
Jimsue's Avatar
Thanks all...being new to RV electronics, is it safe to assume "Romex" is a generic term referring to all different gauges of wire, including the 6 gauge wire I am going to use to connect to the fuse box? Sure would be nice to not have to wrestle with that 6 gauge wire and use something I could easily bend and insert in the connectors!
2013 Sabre BKOK 31
Old 01-14-2016, 08:09 PM   #8
AquaMan's Avatar
Get a section of 6-3 appliance cord from Home Depot or Lowes. Won't take but a foot or two. This wire is a high multi-strand wire and very flexible. Makes maneuvering the wire much easier.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-14-2016, 08:46 PM   #9
Jimsue's Avatar
Hey Fonzie... I don't think that the link you posted works. It linked to some postings from 2006 that made reference to something apparently not related to the topic we are discussing. Can you repost it?
2013 Sabre BKOK 31
Old 01-14-2016, 08:48 PM   #10
Jimsue's Avatar
Aqua man, thank you for your advice. I bought some 6-3 wire at home depot, see the attached picture, and it is as stiff as a board and very difficult to maneuver. Is there more than one type of 6-3 cable? Hopefully, I can return it and get something a little more flexible, if such wire exists.
Name:   ImageUploadedByForest River Forums1452822513.877051.jpg
2013 Sabre BKOK 31
Old 01-14-2016, 08:53 PM   #11
BombDoc's Avatar
PM TURBS. I believe he has pictures of his install. He and I installed mine in Goshen 2014. We installed it under the steps, I did not use the quick connects. I put the LED display under the lip of the steps out of the way of foot traffic so that I could sit in my recliner and see the read out. It is a fairly straight forward job if you are mechanically inclined.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-(20) 2019-0
BombDoc is offline   Reply With Quote
Old 01-14-2016, 09:09 PM   #12
Jimsue's Avatar
Thanks Bomb-Doc. I'll PM Turbs.
2013 Sabre BKOK 31
Old 01-15-2016, 12:27 AM   #13
Just did mine, used 2 range cords and receptacles.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 01-15-2016, 06:45 AM   #14
fonzie's Avatar
Fonzie
Old 01-15-2016, 07:28 AM   #15
RSchleder's Avatar
I talked to FR warranty dept a year or so ago and they explained the "new" extended time period of applying for the 2nd year warranty had to do with the "type of payments they would accept". Not sure how that all works, however, that was their answer and I guess their sticking to it!
If I had to guess, my guess would be there's also a recognition that dealers are not spreading the word, as in not offering it, and FR wants to give new owners a longer period to apply.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 01-15-2016, 07:40 AM   #16
Is this a 50A ? Youroo!!
Old 01-15-2016, 07:43 AM   #17
AquaMan's Avatar
Aqua man, thank you for your advice. I bought some 6-3 wire at home depot, see the attached picture, and it is as stiff as a board and very difficult to maneuver. Is there more than one type of 6-3 cable? Hopefully, I can return it and get something a little more flexible, if such wire exists.Attachment 97838
The cable you got, was standard multi strand 6-3, ask for appliance cord. It has about 3-4 times as many strands and is highly flexible. It would be the same type of cord Dwilcox used on his install. I think it cost around $5.00 a foot when I bought mine. Bought a new EMS to put in the Georgetown, but haven't installed it yet. Will try to make it out to HD and check price of wire.
Old 01-15-2016, 05:43 PM   #18
pashooter's Avatar
Here's my installation. I figured I'd save the cost of the plugs & sockets and do a "permanent" install. If I ever want to remove the unit it will be a much easier job to remove the unit and splice the wires than the initial install was... plus it has a bypass switch on the control unit if you ever need to do that.
http://www.forestriverforums.com/for...d-94602-3.html
Later on in the thread I show how I mounted the display unit inside the coach.
Just another option.
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2019: 76
pashooter is offline   Reply With Quote
Old 01-16-2016, 01:55 PM   #19
Jimsue's Avatar
Aqua man thanks for the advice...I want to both Home Depot and Lowe's and the only cable they had that meets the specifications were range cables with the plugs attached.
2013 Sabre BKOK 31
Old 01-16-2016, 02:59 PM   #20
It is also referred to as "SO" cord. S oh not S zero.
PM sent Jim.
Dale & Karen
