Old 04-29-2016, 08:29 AM   #1
CP3
Has anyone mounted 2 12v battery boxes on Cherokee 274DBH?
I just purchased a 2016 Cherokee 274DBH and want to mount 2 batteries in place of the one. I measured it this morning and the boxes themselves will have an inch of clearance. It's the lids that appear won't fit. Has anyone been able to mount 2 boxes and batteries? If so, did you do anything special or did they just mount up? If not, how did you make it work?
CP3 is offline   Reply With Quote
Old 04-29-2016, 08:44 AM   #2
Pickin' & Campin'
A couple of the ones I did in the past required the adjoining lids to be trimmed slightly.
Easily done with snips or a saw.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-29-2016, 09:42 AM   #3
Too Tall's Avatar
Yes, Not the same RV but my tongue requires trimming the lids. I ended up going with two 6 volts and a Century plastics box. I think FF engineers did a poor job in the battery area.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 04-29-2016, 09:51 AM   #4
KMP44's Avatar
I also trimmed a little of one of the plastic lids to get 2 boxes to fit.
Last year I bought an aluminum box to hold both batteries. It was just big enough to hold 2 gr24's and still fit on the tongue. I went for the black powder coat - looks great. A little pricey, but with extra wires for my solar charge controller and inverter, it cleaned up the wiring to have just one battery box. Only downside to this box I that it isn't quite tall enough for 2 6 volt batteries, but perfect for 2 12 volt batteries. The 27" wide version is taller, but was too wide to fit on the tongue without moving stuff around.
Link:
Featured Products
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 04-29-2016, 10:08 AM   #5
Georgia Frog Rally 2018
aceinspp's Avatar
I mounte the 2nd one to my tt no mods needed other than to make a longer holding plate. to hold two batteries. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 04-29-2016, 10:14 AM   #6
Originally Posted by Too Tall View Post
Yes, Not the same RV but my tongue requires trimming the lids. I ended up going with two 6 volts and a Century plastics box. .
I have this exact set up. If you need the extra amp hours of 2 batteries, you might as well go 6 volt.
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 04-29-2016, 10:38 AM   #7
Only problem with (2) 6volts is if you loose one, you are SOL for 12v. Not so with (2) 12volts.
Old 04-29-2016, 10:49 AM   #8
Same problem with (2) 12v. If one 12v shorts out it will kill the other one and you will be in the same situation, no 12v.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 04-29-2016, 10:53 AM   #9
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by CP3 View Post
...how did you make it work?
Back to the original question.
Instead of trimming, I turned the batteries (as in front to back) opposite so the tops wouldn't have the wire openings adjacent.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 04-29-2016, 10:56 AM   #10
i think you are both right. its a gamble either way, however, this user wants more battery power and the best way to do this is using 6 volt.
battery, cherokee, mount
