12-14-2018, 06:43 AM
Having a hard time choosing generator set.
So the Father in Law told me to pick out a generator solution so he can get it for us for christmas.
I won't need them down here but once this thing gets to Alaska, generating power will be crucial. Especially since there are a few times a year where early spring and late fall use will be necessary and will still be below freezing. I also want as quiet as I can get, but I'm not asking him to buy us a $4500 Honda 7000 whisper watt...
I have narrowed my choices down to two different parallel setups. The trusty Honda 2200/companion (I ran the dog crap out of these when we used to set up remote mining camps in Alaska, and love them) or the Champion 3100/3400 (not dual fuel) that use the 50 amp plug kit.
Our Camper is a Vengeance 306V, 50amp service with one 13.5btu A/C, residential fridge and I will be adding a deep freeze during hunting seasons. I may have to add additional heaters on some trips and want room to run those, which is why the champions stand out a little for me. The champion set comes out significantly cheaper ($870/ea at Lowes, plus my 10% mil discount) vs $2100 for the Honda set, but I know the hondas and trust them, the Champions are the unknown to me.
I would love to hear your opinion on the matter, or feel free to suggest another option. I will not have a harbor freight in Alaska, so the super cheap predators are out of question, haha.
Just your friendly neighborhood combat engineer.
12-14-2018, 08:03 AM
Coach
I've always had good luck with my Champion generators. I own a 3500/4000 contractor style that I've had for over 10 years and still abuse to this day. Liked it enough that we bought the 3500/4000 digital hybrid. It's an open frame inverter. Not as quiet as the closed bodies but much quieter than contractor models. Even with your Lowe's discount don't be afraid to shop around. We bought our last genny online from ACME Tools. Got a better price than Lowe's, Home Depot, or Tractor Supply could offer.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
12-14-2018, 08:08 AM
All I can say is we gave one of our sons a Champion 5 years ago and it's held up thru rain, snow, mud, two tornado's that took out their power for several days. Runs his trailer, used it on mine, tons of power tools. Not the quietest thing in the world, but I've heard worse at CG's. We paid around 6 or 700 if I remember correctly. It's been a great investment.
12-14-2018, 08:10 AM
Trailer Park Supervisor
Got a pair of the Champion 2000 W inverters and parallel connector for just under 800 bucks early in the year at Blain's Farm and Fleet (they shipped them pretty cheap). Still haven't had the chance to fire them up, I really need to make sure they work before warranty runs out! They are nice and light (relatively) at only 50 lbs each, easy to maneuver.
Yes, I drink the water!
The Turners...
12-14-2018, 08:12 AM
Oh, since you mentioned Alaska, pay attention to the elevation you will be at. You have to calculate how much power loss you will have at high elevations and take that into account ( I think above 4k feet)?
12-14-2018, 08:16 AM
That Powermate is not an inverter generator, and is really not suitable for RV use, both for clean power to protect RV electronics and won't be quiet.
12-14-2018, 08:20 AM
If having reliable power is crucial, go with the Honda inverter solution. If you feel bad about having FIL spend so much, offer to split the cost with him.
Champions are indeed cheaper, but for those of us that use inverter generators more than occasionally, the Honda's hold up better over the long run in our experience. Two friends with Champion inverters carry extra carbs as they regularly have problems with them.
Many in our group have had Hondas well over 10 years with thousands of hours on them. Others who go the cheaper routes, have new generators every few years, negating the cost savings.
Also champions do not have internal fuel pumps as Hondas do, making the use of nurse (extended run) tanks a pita.
Good luck in your travels!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
12-14-2018, 08:55 AM
Another excellent point, the extended tank option is a huge plus for me. I just hope the Honda's can keep up with that on board heater plus another and the fridge/freezer.
12-14-2018, 10:54 AM
I don't have experience with a residential fridge on generator, but I wouldn't think the power draw is that much. Heaters, on the other hand, can suck up a lot depending on what type. We have one small space heater that runs fine with one of our EU2000i. If we use the electric fire place heater, we have to run both generators.
I would add up the draw of items you will be using simultaneously and go from there. It adds up quick. Makes that 7000 look better
12-14-2018, 02:47 PM
NMWildcat has some great points.... I'm shopping for a new generator as well! Thanks NMWildcat!
2016 Coachmen Apex 250RLS Ultra Light 2023 Ram 2500 Big Horn Sport 3.73
12-14-2018, 02:53 PM
I have a Champion 3100w inverter generator. I have had it for several years now. It has never failed to start in 1-2 pulls. It is the non remote version. I paid $600 for it shipped back then. It has the 30A connection and I use it at home and use it to power my TT.
I think that maintenance is key with any generator and greatly contributes to it's longevity. I usually run the non ethanol gas in mine which helps. I will run it through with that if I know it may sit for a while between uses. Regular oil changes too.
A side note, mine did not come with an hour meter so I could track usage. I purchased an inexpensive one off ebay and it works great. Took 10 min. to add to it.
Its similar to this one: https://www.ebay.com/itm/Motors-Tach...iVf:rk:17:pf:0
Bobby
2021 Nights Camped 53
2020 Nights Camped 44
2008 Rockwood Freedom 1640LTD
2016 Ram 2500 Tradesman CTD
12-14-2018, 03:25 PM
Have them and run the crap out of them with never a problem. I cannot load/unload 100+# any longer and these 2 at 48# work. Now thinking of find a truck bed tool box to store & transport them. Will also vent as I am thinking of running one while on the road.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
12-14-2018, 03:40 PM
A few days ago someone posted a note to buy a Firman genset 3200 start 2900 run limited lifetime warranty sold by Costco. for 479 no shipping but tax. Picked one up, got it today. Read lots of reviews and the manual ... it is lifetime warranty on the important stuff. Call Arizona and they troubleshoot and send the part. Can't ask for better than that since I'm a handy guy.
12-14-2018, 03:48 PM
2018 Flagstaff E-Pro 19 fbs
12-14-2018, 05:33 PM
Firman Generator
Running it now. Wow so quiet compared to my antique no name. Started on a half pull out of the box. Parallel ready by the Firman box and plug into 30amp or 50 amp outlet. All important hour meter
12-14-2018, 06:06 PM
Just to add to the confusion. And up-front, I have no idea on the reliability, but just saw that Menards has the Westinghouse iGen 2500 on sale for $600. 2500 starting 2200 running watts. Weighs in at 50lbs. Can be paralleled. The one on sale is camo color. Not sure, it may have free shipping - they will ship free to me in Michigan.
https://www.menards.com/main/p-15190...m=flyer_hosted
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
12-14-2018, 06:15 PM
I'm looking at a Champion 3550 Dual Fuel that claims to be fairly quiet, and the power is claimed by Champion to be less than 12 to 20 %THD, and safe for RV use. Are they misleading me?
Right now it's on for half price- very tempting.
12-14-2018, 06:24 PM
FYI- northern tool has online special running that if you spend 1000, you get $200 gift card. Buy the two Honda’s in seperate transactions and use the cards for more tools and poop
Just glad to get away
12-14-2018, 06:38 PM
We have a Champion 3100 that gets used a couple of times a year and we’ve never had issues with it. Every time we put it away we run it out of gas then put in some 50:1 2 stroke gas and run that out. The unit starts first pull every time.
If I had to do it over again I’d get 2 of the 2000’s and a parallel kit. If I used it in BFE all the time I’d get 2 Honda’s.
Former Owner of
2016 Cedar Creek 36 POS (My Last FR Product)
