Originally Posted by Tex8492
Sorry i have been out for awhile. The issue was fixed. The main breaker was not wired correctly so i did have a power surge. Everything has been fixed and functions good now. Thanks
I must admit, I have been following this thread since posted. I'm confused about the
"main breaker was not wired correctly" ? You have only three wires, and the load wire must attach to the breaker which attaches to the load bus on the service panel. The neutral is the neutral, and the ground is the ground. If the load was attached anywhere other than the CB then you would have a direct short and it would immediately trip the breaker and cut off all power on that circuit.
