Old 11-12-2014, 05:28 PM   #1
Heat mattress whilst towing.
I have RW Windjammer3006W. I plan to power a 70 watt heated mattress pad, while towing. I use an AIMS 180 watt pure sine inverter, plugged into the 12v socket under the TV.
Will this combo work while I tow? Will also run refrig & furnace.
ddezurik is offline   Reply With Quote
Old 11-12-2014, 09:47 PM   #2
Dave_Monica's Avatar
Shouldn't be an issue supplying sufficient power from the truck's 12V charging line to keep your camper's battery charged if powering the mattress heater or refrig...think you'd run the battery down if running the RV furnace as the blower fan is a real power hog.
Dave
Old 11-12-2014, 09:54 PM   #3
Ret E-9 Anchor-clanker
donanddona's Avatar
Sounds like layovers in the Walmart parking lot.
donanddona is offline   Reply With Quote
Old 11-12-2014, 10:41 PM   #4
GreenImp's Avatar
Send a message via MSN to GreenImp
I have no experience with your proposition, but I can tell you that your heated mattress will require roughly 6 amps of DC power...far less than your TV's charging system should be capable of. Your 12v outlet should be fine for this. However, at full output (180w) your inverter will require roughly 14 amps of DC power...more than I would be comfortable with long term via a 12v outlet. You may consider hard wiring the inverter?
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is online now   Reply With Quote
Old 11-13-2014, 09:25 AM   #5
You definitely cannot run the furnace. You can only run the frig on "gas" - not nearly enough power to run it on "Electric".
cadman99 is offline   Reply With Quote
Old 11-13-2014, 03:14 PM   #6
Anacortesians
OP - are you British? We are ex-pats. I haven't seen "whilst" in years!
Frank and Eileen
No longer RVers or FR owners
Old 11-13-2014, 03:36 PM   #7
My Mom was English, so I like UK speech patterns.
We have 1 yell lab, 6 yrs that we run in AKC Hunting tests.
towing
