Old 05-27-2013, 01:31 PM   #11
Engineer of Crazy Train
ChooChooMan74's Avatar
Originally Posted by Himcules View Post
think you got a typo...
watts = amps * volts.
so 2400 watts = amps * 120 volts
so amps is 20Ah needed...
12 Volt Batteries X 200 amps equals 2400 watts
P (Power in terms of Watts) = I (Amperage) x E (Voltage)
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 05-27-2013, 01:38 PM   #12
Originally Posted by HONDAMAN174 View Post
So...if your calculations are correct, then 2 70ah batteries will keep me above the 50% threshold on the batteries. But that also doesn't include the power hungry furnace. Hmmm...
2 70ah batteries won't do it, as stated, he based it on 120v batteries. You batteries are 12 volts, so you need 200ah just for the mattresses. You would definitely need at least 4 220ah golf cart batteries in my opinion.
Just remember, it take 20 amps at 120v to make 2400 watts, but it takes 200 amps at 12v to make 2400 watts.
Locomotive Engineer
Old 05-27-2013, 01:42 PM   #13
Himcules's Avatar
do all calculations need to be converted back to 12volt whenever an inverter is used?
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-27-2013, 01:47 PM   #14
Yes. Watts is watts, no matter if it is 12 volts or 120 volts. That is the amount of power something takes. And, there are inverter inefficiencies that were not calculated in. But, I didn't count that, because after a few hours, I bet he would put his heated mattress down to 1/2, unless, he is camping in below freezing temperatures.
Locomotive Engineer
Old 05-27-2013, 03:53 PM   #15
bikendan's Avatar
i've never seen any post about someone doing this.
without a large battery bank, i don't think you could do it for the whole night.
and the furnace drain would add to the problem.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-27-2013, 04:18 PM   #16
HONDAMAN174's Avatar
But see...this is why I love the forum. When you have an idea and unsure whether it will work, you can ask before spending $$$ and it not working. Still might pick up a 1500 to run a TV/DVD for entertainment.
Just glad to get away
Old 05-27-2013, 04:29 PM   #17
too put it simply ... heat means power in the 12volt world ...
inverters just add confusion to the equasion ...
simple facts ...
the more storage space on-board .. like two large 12volt deep cycles in the 31 size range, or some a 6 volt combination ... the less your in the battery burn-out zone .. which every retailer like to see ....
hey its camping .. yea my wife enjoys the heated matteress ... but if you are off line .. enjoy the surroundings .. and monitor the 12 volt power ..
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 11-12-2014, 05:20 PM   #18
I have RW Windjammer3006W. I plan to power a 70 watt heated mattress pad, while towing. I use an AIMS 180 watt pure sine inverter, plugged into the 12v socket under the TV.
Will this combo work while I tow? Will also run refrig & furnace.
ddezurik is offline   Reply With Quote
Old 11-12-2014, 06:45 PM   #19
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Wheww! I think I'll stick with a good pair of insulated long johns and a pair of wool socks. A little coziness with my sweetie won't hurt either.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 11-12-2014, 07:04 PM   #20
Flybob's Avatar
Regardless of what you run on the inverter, running a 1500W inverter at 80% will drain over 100amps per hour from your battery. Two 70 Ahr batteries drawn down to 50%. will not last an hour.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
