Old 08-29-2013, 11:34 AM   #1
Heater Help II - running on batteries?
We got the answer to our question, thanks! Now if you don't mind we another question, can we run the furnace off of 2 12volt batteries? And what would be the duration of the batteries?
Gensca is offline   Reply With Quote
Old 08-29-2013, 11:38 AM   #2
TURBS's Avatar
Yes you can run off of 12 volt/propane.
Usage and battery size will determine battery life.
Do You have the means to recharge it?
Old 08-29-2013, 12:03 PM   #3
Thanks! But can we expect the 2 12 volt marine batteries, hooked up in series to last one night with the thermostat set low (70*F)?
Old 08-29-2013, 12:08 PM   #4
Fulltime family RVer
I really have no idea here. I know the furnace is one of the biggest battery consumers, but I don't have the foggiest idea how much or how long the batteries will last.
What do you know about the batteries? How many amp-hours are they? Are they definitely deep cycle batteries?
(And, that's about the extent of my knowledge! Others will need to chime in.)
Old 08-29-2013, 12:08 PM   #5
TURBS's Avatar
Many variables here but the short answer is you'll likely get through the night if they are fully charged when you start.
I've went one night on one battery but it wasn't that cold.
Variables :
Battery/batteries condition. "Age"
Outside temp /windchill.
R value insulation of camper.
Thermostat setting.
Size of camper.
Etc etc
Turbs
Old 08-29-2013, 12:09 PM   #6
Triguy's Avatar
As Ron said, the furnace will work with your 12volt system.
As for how long those two batteries last depends on the following:
  • What kind of battery and how big (In amp-hours such as the 20hr rate)?
  • How long does the furnace need to run?
  • What are your other power needs during the period?
That info will help estimate for you.
Also, keep in mind that you do not want to discharge your batteries under 50% SOC before fully recharging. So, you basically have half the capacity you think you do.
Here's a nicely written primer on everything 12 volt.
Forest River Forums - Downloads - 12 volt side of Life
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-29-2013, 12:09 PM   #7
Series connection is a really bad idea since that will give you 24v and cook everything. I'll assume you meant parallel.
You'll have to tell us the amp-hour rating or "reserve capacity" of the batteries in order to get an answer. Marine batteries are not all the same.
Old 08-29-2013, 12:10 PM   #8
TURBS's Avatar
Average Furnace amp draw is 10-12 amps.
Fyi
Turbs
Old 08-29-2013, 12:15 PM   #9
Scott, what's SOC?
And Ron, the 12-15amp? How does that relate to amp hours?
Old 08-29-2013, 12:17 PM   #10
Triguy's Avatar
Scott, what's SOC?
My apologies to the OP for the arcane lingo.
SOC = "State of Charge".
Scott
2012 Shamrock 233S
heater, batteries
