Old 08-18-2013, 02:58 PM   #1
Heater/Water Pump Issue
Hi, Everyone.
We just bought a used 2003 Rockwood Freedom pop-up. The water pump and heater work fine when plugged into 110. But, they don't work when the pop-up is running off the battery. My husband thinks there is an in-line fuse somewhere that needs to be replaced but can't find it. Does anyone know where it is located or if you think this is the issue to begin with? Thanks so much!
popolary is offline   Reply With Quote
Old 08-18-2013, 03:21 PM   #2
I assume then that he's verified that the battery is charged? The fuse will look something like the picture below and is usually within a couple of feet of the battery. It may be resettable (eg, not need to be replaced).
Old 08-18-2013, 03:49 PM   #3
He says the lights/fan will run off the battery, so he thinks the battery is charged. I will show him the image you posted. Thanks so much.
He was wondering if that fuse would be outside.
Old 08-18-2013, 04:10 PM   #4
Yes, they are commonly outside.
Old 08-18-2013, 04:37 PM   #5
I've got to say that I have a hard time seeing a failure mechanism that would give some things work and some don't, but all work on shore power. I can see this only if your converter (battery charger) had multiple outputs and that would be unusual.
It sounds like battery voltage might be too low, and while that might stop a heater from working, it wouldn't stop the water pump I don't think.
Any one else see how this can happen?
Old 08-18-2013, 05:39 PM   #6
He looked around the battery and found something that was about the size of a small snickers bar that was black. He's not sure what he is looking for. He didn't see anything that looked like your pic you posted. He is going to charge the battery to see if that makes any difference. Thanks.
heater, pump, water, water pump
