Old 07-05-2015, 08:21 AM   #1
HELP! 2005 Forrest River pop up, new battery dead
2005 pop up, first trip and we are having problems. It is connected to ac power but the lights are dim and co2 detector keeps going off. I replaced with new battery but it was drained in 12 hour. We are on vacation and need help, also we don't have a owners manual yet to help out. Thank you
fuzzymaster is offline   Reply With Quote
Old 07-05-2015, 01:23 PM   #2
bikendan's Avatar
If you're still connected to AC power and the new battery is dead, the most likely culprit is a bad converter.
It's supposed to recharge the battery, which runs the lights and CO/propane detector.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-05-2015, 02:03 PM   #3
Yup most like key bad converter. To get by the rest of the trip go get a small batter charger and hook up to battery. That will get you by for now.
2016 Flagstaff 23lb
Toddupton is online now   Reply With Quote
Old 07-05-2015, 05:01 PM   #4
Oh boy, I was hoping bad connection somewhere. That makes sense though, thanks much.
Old 07-05-2015, 05:24 PM   #5
WolfWhistle's Avatar
Is there a power panel in the trailer with fuses and circuit breakers. If so, make sure all AC breakers are on. Of course, make sure you are getting power all the way from pedestal to the camper. If you have something that runs on AC, plug it into the cord and find out.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 07-06-2015, 02:24 PM   #6
Check the battery voltag with shore power on. Should be above 13 volts
Harkerr is offline   Reply With Quote
Old 07-06-2015, 02:29 PM   #7
What pop-up do you have, does the converter have the ability to charge the battery? My popup had a switch for battery or converter but the converter did not charge the battery.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 07-07-2015, 08:13 AM   #8
peaceparson
We have a 2002 FR pop-up with a converter also. The manual warns against attempting to charge the battery off the converter--not designed to do that. I have a small charger on-board, and use that to keep powered up. For safety sake, I disconnect the cables from the battery while charging--don't want to accidently burn something out. Also, there may be a fuse or fusible link under or near the battery on the trailer frame which ought to be checked. Some have a reset button. If this needs attention, you won't get power no matter what else you try.
peaceparson is offline   Reply With Quote
battery, pop up
