Old 08-23-2013, 08:49 PM   #11
member
its plugged into a 30 amp plug thats what is driving me crazy you would think one of the breakers would trip
2016 Rockwood 8310SS Signature Ultralight
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 08-23-2013, 11:24 PM   #12
I would suspect that the connection that caused the melting was a poor connection. When there is a poor connection it causes high resistance at the connection. High resistance causes heat, as the connection heats up, more resistance is created until it is hot enough to cause the melting. At some point in time the connection probably corrected itself so you didn't see the problem in the usage of the powered items in the trailer. Since you are not overloading the circuit, the breaker won't trip. With the replacement of the melted plugs you probably won't have a problem, but I would occasionally carefully check the connection for heating up.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 08-23-2013, 11:46 PM   #13
1A Camper's Avatar
I am going to correct 09grizzly1 a little. Not high resistance just some resistance. With as little as one ohm and 30 amp you are generating 90 watts off heat. Ever touch a 100 watt light bulb. Here the math ohm law voltage = amp x ohm. watts = amp x voltage.
Now that you are dropping 30 volts at the connection you are now trying to run the AC on 90 volts it is going to even try to pull more amps.
Now you can see how just a little corrosion/dirt could cause a problem.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 08-23-2013, 11:50 PM   #14
My bad and I know it only needs to be a small amount of resistance to cause a problem.
09grizzly1
09 Grizzly 700 EPS
Old 08-24-2013, 06:03 AM   #15
member
Thank all of you for your replies I understand why the plug may have melted . My new ? is why wont any breakers trip when i intentionally over load them to test it. I had the AC ,toaster,hair dryer,and micro on and never tripped a breaker . I can remember when the AC was on and the wife dried her hair the breaker tripped every time before . So I was wondering if this is a problem and what it my be? Could it be the converter?Every thing is working fine and I'am not having any other issues with any thing else 12 v or 110. THanks again everyone hope someone can give me a answer.
Old 08-24-2013, 07:16 AM   #16
KyDan's Avatar
A loose or weak connection can and often will over heat.
Even a brand new power cord and a brand new male connection on your
trailer can do this. MY power cord plugs onto the trailer very easy.
It's not melted anything--yet but if it did, I would not be surprised.
Sometimes when they mold those cord ends they can get just a tiny bit
of plastic in between the contacts in the female end and it can cause
a weak connection and result in over heating.
Don't freak out on not tripping your breakers until/unless you use an
actual clamp on ammeter and KNOW for sure what current is passing
through a particular circuit. Unless you use a real meter you are guessing.
It sucks that you need a new cord and socket! Remember the old boaters
mantra- A boat is just a hole in the water you pour money into.
RVs can be considered land yachts!!
Fix it, move on,
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-24-2013, 07:35 AM   #17
I don't know. With everything he had on it sure seems like a reasonable guess that it was over 30 amps. It's not going to trip right at 30 right away, but does sound like you have good reason to have the breaker checked out (or actually, it's probably cheaper to just replace it).
Old 08-24-2013, 07:41 AM   #18
I agree with you,I know of (NO) other camper who can turn on all the (Heavy Load) components that you have at the (Same) time,and (Not) trip a breaker! You have a (Big) electrical problem!
You have a great chance of a (Fire) if not Checked before pluging & use agin! Youroo!!
Old 08-24-2013, 10:04 AM   #19
I agree with KyDan on checking the draw with a meter with all the electrical items on before condemning the breaker, although as BarryD0706 indicated it might be cheaper to just replace the breaker.
09grizzly1
09 Grizzly 700 EPS
Old 08-24-2013, 10:32 AM   #20
Herk7769's Avatar
Not religiously twisting and locking your connecting ring (while running the AC) will do this. Don't ask how I know...
PS not my photos. My connectors did not show water corrosion; just the burns.
ID:	38540   Click image for larger version
HAM CALLSIGN - KC3FFW
