Old 08-18-2013, 04:06 PM   #1
member
Help 30 amp cord melted
Has any one ever had this happen to them.I went to disconnect my detachable power cord today to go home and I couldn't get it off .So after twisting and pulling for a half hour I just wrapped it around the bumper and went home . When I got home I took it all apart and found that the white wire had heated up and melted the prong to the receptacal. I dint experience any electrical problems all weekend . Even when I got home I plugged it in and everything worked fine.I now have to replace both the plug on the cord and the receptacle on the rv . Any help or suggestions would be appreciated . Thanks in advance
2016 Rockwood 8310SS Signature Ultralight
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 08-18-2013, 04:29 PM   #2
wmtire's Avatar
It makes you wonder if the cord and the trailer outlet didn't connect correct and there was arcing.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-18-2013, 04:39 PM   #3
member
Thanks for the reply, would that cause any interruption in power because we never lost power all weekend
Old 08-18-2013, 04:54 PM   #4
wmtire's Avatar
Not necessarily. If you had a slightly bad/loose connection.......and was getting electrical arcing across the connection between the trailers outlet terminal(s) and the cord terminal(s).......it could still provide power ........up to the point something burned all the way thru. Sounds like your connection melted to the point of being fused together between them.
You usually hear about this kind of thing happening at the other end...where you plug your RV's cord into the campground's outlet.........due to bad/loose/worn out connectors in the campgrounds outlet.
Old 08-18-2013, 06:08 PM   #5
lindy's Avatar
How much of a load were you pulling and for how long a time, i.e. A/C & Microwave: Microwave & hair driers; Hair driers & curling iron; Coffee pot & any of the previous. If you were pulling close to 30amps for and extended time this will melt a cord/plug connection too.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 08-18-2013, 06:59 PM   #6
Firefighter969's Avatar
I had that happen to me in my previous TT I did not have a EMS installed. It melted the Male end at the pedestal found out the park was low on power in my area and I was drawing to many amps. Had to run to Walmart and get a new cord for the rest of my trip. Now I have a EMS also check connections seen some melted.
2000 F250 Superduty CC LB 7.3 4x4
2013 344QB Wildcat
Nights camped 2014 ( 15)
Nights Camped 2015 ( 4 )
Firefighter969 is offline   Reply With Quote
Old 08-18-2013, 07:07 PM   #7
papap's Avatar
this use usually caused by a old plugin at the campground. People plugin and unplug without turning the breaker off.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 08-23-2013, 07:08 PM   #8
member
I fixed my melted cord ends and tested my power. After doing so, i wondered if the problem might be my breakers. I ran the air conditioner, toaster, hair dryer, and microwave all at the same time and never popped a breaker in the camper or the 30 amp at my house. I'm thinking this could be why i fried my cord. Any advise or help would be appreciated.
Thanks.
Old 08-23-2013, 08:36 PM   #9
member
Ok lets try this does any one know why a breaker wont trip when you purposely over load it .and could this melt my power cord
Old 08-23-2013, 08:46 PM   #10
wmtire's Avatar
Thanks.
WOW!. What do you have it plugged into at your house?
