Old 06-28-2014, 02:07 PM   #1
Auto4's Avatar
Help
While plugging my camper into shore power at my home I heard a pop and smoke began coming out of the plug. This was 15 amp to 30 amp. I've done this same routine hundreds of times in the past.
I don't think it's the 15 amp extension cord because it works when plugged into other things. I don't think it's the 30 amp extension because I can plug that into the 15 amp cord without issue. It's only when everything is hooked up to the camper that I have issues.
What is causing this to happen??????
Auto4 is offline   Reply With Quote
Old 06-28-2014, 02:13 PM   #2
fonzie's Avatar
Shut all your breakers inside the camper. Hook up everything outside. Close main AC breaker, if OK then close other breakers one at a time. You might have too much load at once and it overloads 15 amps receptacle??
Fonzie
Old 06-28-2014, 02:17 PM   #3
dcheatwood's Avatar
This is a good initial step. keep us informed.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-28-2014, 03:04 PM   #4
Auto4's Avatar
Well that worked. Like I said before. I've done this 100 times in the past and have never had this issue. I turned off all the breakers and tuned them on one at a time starting with the 30 amp then the two 20 amps then the 15 amps and sure enough it worked. Thank you very much. I was in a panic mode considering we're going camping on Wednesday. This forum is awesome.
Old 06-28-2014, 03:25 PM   #5
Herk7769's Avatar
Check your water heater. You may have left it on AC from your trip.
1500 watts is 12.5 amps all by itself.
HAM CALLSIGN - KC3FFW
