Originally Posted by rk06382
I read 'Dometic Refrigerator Diagnostic Service Manual' in regards to 'The heat load of the 10 watt light bulb will cause the cooling unit to cycle approximate every 35 to 55 minutes.'
My fan will replace the convection air flow of the 'The heat load of the 10 watt light bulb.'
Attachment 199715
Sec 5.12 Low Ambient Switch on page 18 of Dometic Refrigerator Diagnostic Service Manual.
You stated your fan pulls 0.15 amps. 0.15amps x 12 VDC = 1.8 watts. So 18% of the heat load of the 10 watt light bulb.
Good luck.
2011 Traverse LT, 3.6L, FWD
