Old 03-16-2019, 12:03 PM   #1
Help. Dometic Refrigerator Light
While attempting to wire an internal fan to assist with cooling, I thought I could tap in to the 12v from the light. I disconnected the wire to switch, cut off the female adapter and connected the positive lead only to realize it will only feed power when the door is open. Duh. It was at the end of a long day and I decided to stop and start again another day. Well, two weeks later and I can’t remember how the switch was wired before. I should have taken an image of the switch so I could reference later but...duh.
Anyways, I need help putting this back together. Concerned if I wire it wrong I will short the frig out. Pretty sure they have engineered it so I can’t fry it but I want to be sure. Where do these wires go? Bonus points if you can advise me where to wire the 12v for the fan.
TomLerch is offline   Reply With Quote
Old 03-16-2019, 12:07 PM   #2
another image
Old 03-16-2019, 12:18 PM   #3
D W
D W's Avatar
You didn't specify what model Dometic you have, but here is a Dometic 2-way control system schematic. It covers the light and the switch. Hope it helps you out.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 03-16-2019, 10:18 PM   #4
Thank you. Does anyone have a picture of their internal refrigerator light?
Old 03-16-2019, 11:15 PM   #5
cavie's Avatar
I see 2 12 volts in and 2 12 volts out. The switch is acting as a junction box and a switch. 12 volts comes in and 12 volts goes out to something else. The lever that touches the door turns the light on and off. 2 reds on one screw and 2 blacks on the other. Makes no difference which one. that's the best I can come up with from those pictures.
The 12 volts in and out power other near by items like the range hood, Furnace, Water heater control board.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-17-2019, 08:13 AM   #6
bubbles's Avatar
Don't know your Dometic model but if it has a drain tube to the outside route the wires through it and pick up 12 volts and ground at the rear of the fridge. Those fans typically have a power switch on them so a constant 12 volts from the back is what you should look for. There's typically a power strip associated with the fridge on the backside. Use your voltmeter to locate 12 volt DC power and ground.
Old 03-17-2019, 08:26 AM   #7
Looks like from the photo that Cavie is right except they are not screws. They look like 90 degree female crimp spade connectors. They are normally color coded so if you get the same color it should be the same size. I would just put the two blacks in the spade connector and slide it onto the open male spade. Maybe someone will have a photo of theirs and it will confirm but I think that's right.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 03-17-2019, 09:00 AM   #8
sgtlm17's Avatar
There are two 12v wires on the switch. The feed that supplies power to the switch and the other wire on the switch supplies power to the light when the door opens and the switch is activated. The fan goes to the wire on the switch that feeds constant power to the switch.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 03-17-2019, 09:45 AM   #9
Depending on your fridge model and year, your wiring may look more like this one than like D W's:
Name:	Generic DM2652 wiring diagram.png
If you look on the back of your fridge, there's probably a wiring diagram sticker attached so you'll know exactly which one you've got.
The problem, in both cases, is that the +12 volts goes to the door switch first. Unfortunately, accessing the door switch is very difficult/impossible.
Your two options are routing a wire through the drain hose as bubbles stated in Post #6, or feeding a wire along side the thermistor wire. Both of these options will get you outside the fridge in the back, where you can then tie it into the power block. I tied my external fans into my power block. The power block is the white thing circled in red in the pic below.
Name:	Fans 4 markup.jpg
For the ground wire, you can also route this outside to the power block; alternatively, some people put an alligator clip on it. Clip the alligator clip to the fins and you've got a ground and the fan runs. Remove it and the fan stops. Simple on/off.
Good luck.
2011 Traverse LT, 3.6L, FWD
Old 03-17-2019, 10:13 AM   #10
cavie's Avatar
The op does not need to run wires anywhere. They are right there at the light. Red is positive. Black is negative. You need a voltmeter to determine where the wires went on your light. Wire the fan to the red and black and go to your fan control of some sort and the fan. The photo shows a light and switch combo. He just doesn't remember which wires go. Like I said, the light acts as a j-box, light and switch all in one. See the lever to the right? That hits the door. I just can't see all the contact points to help you any further.
dometic, light, refrigerator
