Old 07-02-2019, 06:39 PM   #1
007matman's Avatar
Help! How do I remove this clip/retainer?
I was going to swap out my RV 7-prong connector cord and my breakaway switch but I found these at the junction box.
Is there a way to release them so they can be re-used? Is there something better I could use in their place?
I tried to pry out on the tabs that secure them and it's a no-go. Click image for larger version
007matman is online now   Reply With Quote
Old 07-02-2019, 07:01 PM   #2
007matman's Avatar
I found 'em online.. looks like it is a Halex connector.
Halex 27516 NON-METALLIC PLASTIC CABLE CONNECTOR 5/BAG 3/4" Gray https://www.amazon.com/dp/B00310T3BI..._Ka.gDbW24504R
Not seeing a way to remove them from the photos.
Anyone?
Old 07-02-2019, 07:34 PM   #3
D W
D W's Avatar
You can remove them from the knockout by applying pressure to the inside lock tabs with a screwdriver, However, it's a locked wedge fit around the wire and generally requires cutting the wire. If you're careful you could probably use a tiny tim type hacksaw and cut the nylon connector. If you're replacing the 7 pin pigtail I would just let it go and put a new connector on the new pigtail.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 07-03-2019, 02:40 AM   #4
007matman's Avatar
Thanks. I was hoping to avoid a trip to the hardware store.
Some of the wiring is short already that goes through there and will need to be re-used. Especially some of the wires in the top one.
Old 07-03-2019, 02:31 PM   #5
Retired
You can remove the connector by placing a pair of channel locks on the two tabs that are just inside the junction box and squeezeing as you push the connector back out past tabs. It may then be reused
billymc is offline   Reply With Quote
Old 07-03-2019, 02:39 PM   #6
Head Rambler
The link that matman posted shows a good picture of the little tab that billymc mentioned. There's one on each side. You can see that you need to press both of them in and then slide the connector back out of the box.
You can pry them in one at a time and rock the connector to free them from the hole, but that's usually more work.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 07-03-2019, 02:49 PM   #7
I tried to pry out on the tabs that secure them and it's a no-go. Attachment 208777
These are Halex snap-in connectors. In use, they're snapped into the hole, the wire inserted, and the rectangular tab (toward the bottom in the picture) is crimped down with channel locks. To remove the wire. I generally get hold of the tab perpendicular to the cable, using a large pair of diagonal cutters. Other kinds of pliers may well work, as it is a "brute force" operation.
As a replacement, a 3/4" romex type clamp would work well, or one of the high dollar dome nut cable strain reliefs, which are also waterproof, for what that is worth.
Photo Lab is offline   Reply With Quote
Old 07-03-2019, 02:54 PM   #8
007matman's Avatar
Will that tab in the middle pop out when I do that? How do I release the cable?
Old 07-03-2019, 03:07 PM   #9
007matman's Avatar
I'll give it another try. Thank you.
Old 07-03-2019, 06:45 PM   #10
007matman's Avatar
Well I couldn't get the push-down wire clamps out so I just replaced them with metal connectors.
Those things are a real pain!
Thanks guys for your help.
