Old 06-17-2016, 06:11 PM   #11
MNtraveler's Avatar
Can't take the dog to the play at Stratford Festival. Can't park near the pedestal due to slope. We're sacrificing the tickets and staying home.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 06-17-2016, 06:32 PM   #12
DAISY BOYKIN's Avatar
30/50 Amp pedestal
Does the pedestal have a 50 AMP connection? If it does, use a 50 Amp cable converter. If you have one. This may solve the problem.
Your pedestal 30 amp breaker circuit may be bad or too much load on the line by all the other campers causing your pedestal to kick off line.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 06-17-2016, 06:43 PM   #13
Carknocker Family
Ida Ratherbe Camping's Avatar
Does your surge protector show line in voltage? May already be low coming in,and with long cord, (the extra 30 ft), you are pulling to many amps.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is online now   Reply With Quote
Old 06-17-2016, 06:48 PM   #14
Herk7769's Avatar
Low campground voltage will do this. Almost always found on the 30 amp loop of older campgrounds that used minimum gauge aluminum service wire.
Move to a 50 amp site and use a dogbone adapter if possible.
Using an autotransformer will boost low voltage at your site and allow the compressor to turn over.
Watch the startup amps and voltage drop as the compressor fires up. I have a 2 second delay relay between compressor start and fan motor start. Before I put the relay in to delay fan startup, the LRA has routinely topped 30 amps; though not long enough to tip the pedestal breaker at a well wired campground.
At a marginally wired campground, low voltage will cause a pedestal trip even with the delay relay and hard start capacitor.
ID:	111392   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 06-17-2016, 07:27 PM   #15
vibe268rks's Avatar
one thing to do is check the power at the pedestal while the unit is on with the ac running.
If you don't have 120 volts while the ac is running at the breaker, then they have a voltage drop issue. This is if you have a meter to check voltage.
vibe268rks is offline   Reply With Quote
Old 06-17-2016, 11:15 PM   #16
MNtraveler's Avatar
30A only. I think it's our load. Tripped two separate breakers. No one else seems to be having trouble. Also eliminated the problem (apparently) by turning off all our other circuits besides AC and converter.
Thanks.
2016 Forester 2401R
Old 06-17-2016, 11:16 PM   #17
MNtraveler's Avatar
Line in has been 117-124V. Pretty steady around 118-120. No line errors.
2016 Forester 2401R
Old 06-17-2016, 11:28 PM   #18
MNtraveler's Avatar
Thanks all for tips and suggestions. The temperature came down at the last hour so we were able to switch to FantasticVent in thermostat and we got to the play although 10 min. late!
The best I can tell without an electrician is the 50' of cord caused some voltage drop which increased the amp draw across multiple appliances. I realized there would be a small voltage drop, for example ---
Name:	ImageUploadedByForest River Forums1466224028.716023.jpg
But didn't appreciate that this would cause an amp increase to fulfill the power demand.
2016 Forester 2401R
Old 06-18-2016, 06:10 AM   #19
Herk7769's Avatar
Attachment 111433
50 foot of extension cord will make all the difference in the world when under load.
It also depends on where you are in the campground as the farther you are from the distribution source the lower the voltage and amps available under load.
ID:	111438   Click image for larger version
ID:	111439   Click image for larger version
Old 06-18-2016, 12:41 PM   #20
Have you checked the voltage at the pedistal and the unit ? the voltage drop shoundnt be mutch,with that load, if it is one or both of the cords my be at fault. Have you tried pluging in to the pedistal directly?
Big Bill is offline   Reply With Quote
breaker
