Old 06-18-2016, 01:22 PM   #21
Bluepill's Avatar
Also: Check the temperature of the 2 plugs and 2 sockets (includes the entry socket) by carefully touching after running the A/C for 10 minutes. They can be warm but shouldn't be hot to the touch.
If one is much hotter than the others, you have a poor connection there.
2008 Itasca Meridian 37H
Old 06-18-2016, 01:34 PM   #22
It looks like to me you have 2 issues, extension cord and running too many electrical appliances. On a 30 amp circuit, don't run any heavy amp appliances when using your A/C, especially the water heater. The extension cord is also a problem, you have a 25' cord from your coach then you've added another 50' of extension cord so you are running 75' of extension cord, with the amp drop over this length you don't have 30 amps at your coach. Another potential problem could be the circuit breaker at the post. It may be weak from popping so many times. When 50 amp is available, I always use a 50/30 adapter.
tomrob1161 is offline   Reply With Quote
Old 06-18-2016, 01:43 PM   #23
Originally Posted by MNtraveler View Post
Line in has been 117-124V. Pretty steady around 118-120. No line errors.
Land of 10,000 Lakes
2016 Forester MBS 2401R
These are good voltage numbers, but are they taken under load? The meaningful number is the voltage under load. A long, or under sized extension cord will provide good readings with no load but the added resistance under load will pull the voltage down, and the amps up.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 06-18-2016, 02:08 PM   #24
In follow-up to my earlier post, here is a list showing typical AMP draws for an RV.
Microwave 12.8 amps
Air Conditioner - 15,000 BTU 12.5 amps
Electric Water Heater – 6 gallon 12.5 amps
Toaster 10 amps
Hair Dryer 10 amps
Electric Frying Pan 10 amps
Electric Coffee Pot 10 amps
TV 2 amps
Crock Pot 1.5 amps
Heating Pad .5 amps
Old 06-18-2016, 02:51 PM   #25
Just to add to this....my 5'er is 30 amp service. I've fought power issues during the heat of summer as well. With 30 amp service, you certainly have to manage your power usage. I bought a 30ft open ended 50 amp power cord and put a 30 amp female plug w/weather boot on it to mate to the trailer. Since then, I've also started running both the frig and water htr on propane. At this point, I think I've conquered the 30 amp blues.
philobeddoe is offline   Reply With Quote
Old 06-18-2016, 06:16 PM   #26
Mrpsyko's Avatar
Could still be breaker on pedestal being week. Even second pedestal could be weak. See if cg will replace breaker.
2017 Flagstaff Super Lite 26RBWS/2014 F150 XLT SCREW 5.0 V-8
https://www.forestriverforums.com/at...pic35767_3.gif
Mrpsyko is offline   Reply With Quote
Old 06-30-2016, 12:01 AM   #27
MNtraveler's Avatar
Yes, those were under load.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 06-30-2016, 12:03 AM   #28
MNtraveler's Avatar
Help needed - A/C keeps throwing pedestal circuit breaker
Microwave 12.8 amps
Electric Water Heater 6 gallon 12.5 amps
Toaster 10 amps
Hair Dryer 10 amps
TV 2 amps
Crock Pot 1.5 amps
Heating Pad .5 amps
Thanks. This does not include the refrigerator which is a big draw (but in and off so you might miss it when taking readings) or the converter (charger) which is usually a small but continuous draw.
2016 Forester 2401R
Old 06-30-2016, 12:07 AM   #29
MNtraveler's Avatar
Thanks all for the help and suggestions. I'm pretty sure it was the extension cord plus the combination of things that were on together.
Later in the trip we needed the heat pump at night and even with extension cords either 50' or 100' in total line (yup) I had no problem with it as long as I turned off the hot water heater. Refrig on but not working too hard in cold nights (down to 45) and converter on.
2016 Forester 2401R
Old 06-30-2016, 08:22 PM   #30
Canadian Member
itat's Avatar
Would a hard start capacitor on the AC help reduce the amp draw from the AC on start up and therefore the voltage drop? I've had the low voltage problem at a local Provincial Park. The pedestal only had about 110 to 111 volts.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
breaker
