So everything worked when you plugged it in to your house. That means the converter is working just fine.
I'd say there are three possibilities:
1) There is a battery-disconnect switch which is off. Find it and turn it on.
2) There is a fuse in-line with the battery cable which is blown. It will look something like the picture below.
3) The battery wire is disconnected somewhere else.
