Old 12-17-2014, 06:29 AM   #1
Help.. No power from battery to TT 27hfs
Hoping someone can help me out. I am not getting any power from my battery to inside my camper. I know the battery is fine and the electric jack is working, all fuses and breakers in the main pannel look good. Is there a in line fuse from the main power coming into the camper from the battery that I might be missing?
2013 XLR 27HFS
2007 GMC Duramax
creed is offline   Reply With Quote
Old 12-17-2014, 07:01 AM   #2
Batts-toy's Avatar
At the battery, starting at the positive post look for a small breaker that has tripped. Some are on the battery post, most are under the TT attached to the frame. Follow the positive wire the breaker it will be metal usually silver in color and some have a little black reset button. If you have a test meter test on each side to see if power goes through it. If it is the type with no reset button you will have to replace it.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 12-17-2014, 07:07 AM   #3
Batts-toy's Avatar
Another possibility is there are two 40 amp fuses in you electrical panel that protect the TT electrical circuits in case the battery gets hooked up backwards or the is a sudden large power flow, you should also check those f you haven't already.
Old 12-17-2014, 07:29 AM   #4
This is how the main power runs to the frame from the battery.
2013 XLR 27HFS
2007 GMC Duramax
Old 12-17-2014, 11:53 AM   #5
We had the same problem last year. All our fuses were fine, battery fine. Converter had gone bad. If you plug into home/campground electric, do you have 110 (outlet) in the camper, but no DV (lights). If so, could be your converter, like us.
hotzfamily is offline   Reply With Quote
Old 12-17-2014, 12:03 PM   #6
When plugged in the lights and outlets work.
2013 XLR 27HFS
2007 GMC Duramax
Old 12-17-2014, 01:18 PM   #7
Grn_Mtns's Avatar
Our windjammer has a shut off switch with a red button for the DC up in the V nose. Do you have one? Look around.Could be anywhere!
It is easy to tap it closed. Good luck. If plugged in works then converter should be fine..
Best,
Grn_Mtns
____________________________________
2018 8329 SS Rockwood /260watts solar
Grn_Mtns is offline   Reply With Quote
Old 12-17-2014, 02:23 PM   #8
fonzie's Avatar
As Batts-toy mentionned see if there is small black button on side of breaker and press to re-set.....as shown in picture.
Fonzie
Old 12-17-2014, 02:28 PM   #9
Maron
Send a message via Yahoo to Maron
Call Forest River and talk to one of their techs up in Goshen...or is that Verbotten on this blog? They had a "Know Everything" electrical guy at the FROG convention but I can't remember his name. I even had him stop by our 8329 to help me out with the TV set up. It's a pain to get old.
Maron is offline   Reply With Quote
Old 12-17-2014, 03:04 PM   #10
How about your battery terminals, could they be corroded and not making good contact?
saltyman is offline   Reply With Quote
battery, power
