Old 08-25-2015, 05:08 PM   #31
Flybob's Avatar
Just run 1" or 3/4" flex tubing from front to back securing it to frame with conduit clips. Now you have easy access for any front to back wiring including wired camera, lights etc.
Carlon 1 in. x 25 ft. Flexible Electrical Non-Metallic Tubing-12008-025 - The Home Depot
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-25-2015, 05:33 PM   #32
Karrun, you say the fuses seemed ok. What does that mean? I'm not trying to be mean but did you test them? With key on you can test them with a 12volt test light. ground the light (with attached alligator clip) and then touch the little metallic spots on the actual fuse with the point of the test light) (leave fuses in) Either both sides light comes on or both sides light off. If you run into one side light on and one side light off then that fuse is bad. It would take 10 seconds to show you...writing it out makes it sound so difficult
2015 274 RK LIMITED <'{{{{><
captainperry is offline   Reply With Quote
Old 08-25-2015, 06:32 PM   #33
If you have a manual for your TV, somewhere in that should show a fuse layout or printout for your fuses.
saltyman is online now   Reply With Quote
Old 08-25-2015, 07:33 PM   #34
karrun's Avatar
Originally Posted by Herk7769 View Post
Put the voltmeter on the 20 volts DC scale.
Turn on the hazard lights and the parking lights on the truck.
Open the port that the trailer plug fits in.
The "Ground" is pin 1 (Lower left pin) - put the black lead on this one.
The Running lights are pin 3 - upper left of the "key" - should have 13 volts with truck running or key "on".
Okay, I just tried this and got nothing with key to "on" and lights on Durango on. I found two fuse boxes under the hood. . One of the fuse boxes had a 20A minifuse labeled TT Tow. I pulled this and it was bad. I replaced it and thought I was good to go. No luck. Still no lights, and no voltage when trying Herk's suggestion above. Sigh. I can't find any other fuses that seem to have anything to do with towing. There are two relays labeled something like left and right trailer tow, but how do you check a relay? Like I already said, I don't have the fuse layout for the box under the dash inside the cab, so I don't know if any of those have anything to do with towing.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 08-25-2015, 07:40 PM   #35
karrun's Avatar
Also, I've already stated that my under-the-dash fuse panel is missing cover, so no fuse diagram. My owner's manual is no help (says to check the diagram under the cover). I have no idea is any of those fuses is the culprit. I don't have a fuse tester, so I'd have to pull each of the apprx 20 fuses located there and inspect them. I'm afraid I may screw something up if I do that.
Sorry if I sound frustrated. I just don't know what else to check.
2016 Roo 21SS
Mods so far:
Old 08-25-2015, 07:56 PM   #36
kho6658's Avatar
I have a 2005 and they should be the same. Hopefully this helps
ID:	86895   Click image for larger version
ID:	86896   Click image for larger version
ID:	86897   Click image for larger version
2016 Freedom Express 28SE
2017 F350 Lariat
Days Camped 2018 - 6
Days Camped 2017 - 41
kho6658 is offline   Reply With Quote
Old 08-25-2015, 08:01 PM   #37
Whew! What frustration! Glad our TT is pre-wired for a backup camera. Man!
2015 Palomino SolAire 20RBS
2017 1500 Silverado LTZ Z71 with 6.2L, 8-speed & tow package
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 20 days (so far)
elchilero53 is offline   Reply With Quote
Old 08-25-2015, 08:05 PM   #38
Left Coast
As far as relays, just swap two around..ie: wiper and trailer...relay ratings are the same...relay difference is number of pins.. either 4 or 5
Old 08-25-2015, 08:06 PM   #39
Also, go back and double check the fuse that you just replaced to make sure it is not blown again. It could have blown again when it was replaced, which means you have a short somewhere.
Don and Michele
3 Adult Children - 4 Granddaughters
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 08-25-2015, 08:06 PM   #40
karrun's Avatar
Praise the lord and pass the gravy! Found the second bad fuse! The little bugger was hiding in the second under hood panel with no labels for it. Found a website where an expert suggested checking this fuse. Changed it and I am good to go.
I really appreciate everyone's help on this. Now do I just leave well enough alone or do I take a shot at the backup camera again? Just kidding. We leave Friday for camping, not going to take a chance at messing things up until camping season is over in a couple of months.
2016 Roo 21SS
Mods so far:
camping
