Old 06-15-2015, 08:21 AM   #1
karrun's Avatar
Help wiring stair lights
Okay, I admit it I know very little about electrical things. So this would probably be a simple job for someone who knows what they are doing. But I am scratching my head. I want to add 12V LEDs to my stairs. There is a spot in my command center for a switch and I lucked out and bought a perfect match for the spot. But I don't know how to wire it. The LEDs have a + and a - for the ground. My switch has two connectors labeled 3 and 2 and is described: 12 VDC Interior Switch, On / Off
Single On/Off Switch. For interior lighting and appliances. Cut-out: 1.125" x .55". SPST.
and looks like this.
So do I run power (pigtailed from another switch) to one of these, and the + lead from the LED to the other, and run the ground from the LED to a grounded metal piece on the frame? How do I know which connector to run the power to?
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 06-15-2015, 08:22 AM   #2
karrun's Avatar
Not sure why I can't attach picture of switch, but here's the link.12 VDC Interior Switch, On / Off
2016 Roo 21SS
Mods so far:
Old 06-15-2015, 08:30 AM   #3
bubbles's Avatar
Yes, you have it. Sounds like the LED leads are marked for the positive input. Typically the power (pigtail) would be on the switch center most stud but it is just an ON/OFF switch and either switch stud will suffice.
Old 06-15-2015, 08:54 AM   #4
karrun's Avatar
Thanks for the input. I'll give it a shot tonight. As far as working with 12V safety wise, can I safely work with it without disconnecting the battery?
2016 Roo 21SS
Mods so far:
Old 06-15-2015, 09:07 AM   #5
bubbles's Avatar
If you have a battery disconnect switch use that to disconnect the battery and with your multimeter verify no 12 volts on the wire you are going to pigtail off of or the function (switch etc.) for the pigtail source no longer works. You might, instead, pull the fuse for that circuit. It's no different than working on your car when dealing with 12 volts. If you don't disconnect and you happen to touch your pigtail to ground you will blow the fuse for that circuit. It is always a good/safe practice to disconnect the power source when dealing/modifying electrical circuits. It's your call.
Old 06-15-2015, 09:14 AM   #6
Batts-toy's Avatar
Without disconnecting the battery, if you touch the + lead bare wire and ground yourself at the same time you will get shocked.
bubbles beat me to it. Good luck
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 06-15-2015, 10:38 AM   #7
karrun's Avatar
Will do, thanks.
2016 Roo 21SS
Mods so far:
Old 06-15-2015, 03:47 PM   #8
BobHanke's Avatar
Sounds like you are working with a SPST (single pole single throw switch). Check with an ohm meter to see how to get on and off positions situated as you prefer. You could consider getting a tattle tale switch (with light) to know if remote device is on or off.
BobHanke is offline   Reply With Quote
Old 06-24-2015, 07:00 AM   #9
karrun's Avatar
Red face
So I finished my stair mod and thought I'd share the results here. Really happy with the way it turned out. Thanks everyone for the help!
Sorry for the upside down shot
2016 Roo 21SS
Mods so far:
light, wiring
