Old 06-13-2012, 07:45 PM   #1
Ky Firefighter
Help with A/C
Is there a way to seperate the two A/C's from the 50 amp service to where they can run seperate on two seperate hookups
fire2 is offline   Reply With Quote
Old 06-13-2012, 08:42 PM   #2
camper_Lucy's Avatar
They are already separate, if you look at the fuse panel one will be on the right side bus bar, and the other on the left side bus bar. If you are asking if you could add a separate service point and move one unit to it, sure. You would move the wires from the panel to a second "new" panel attached to the new service point. That service point would need to be a 30AMP service. Beware some CG do not provide separate 30 and 50 service at the post, just because the plugs are there do not assume separate runs.
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 06-14-2012, 08:44 AM   #3
cogito ergo moo
Cowracer's Avatar
I gotta ask...
why would you want to?
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 06-14-2012, 09:02 AM   #4
Ky Firefighter
Help with A/C
My Coach requires 50 amp but most campgrounds only have 30 amps
Old 06-14-2012, 02:27 PM   #5
crushor's Avatar
Fortunately, the CG my family and I are going to the first week of July has 30, 50 amp along with 2 -110 outlets to each site.
2007 Ford F250 4x4 Harley-Davidson Powerstroke
2006 Cedar Creek Silverback - 35 LRLBS
(2012 -11) (2013 - 10 so far)
crushor is offline   Reply With Quote
Old 06-14-2012, 03:27 PM   #6
TURBS's Avatar
Could always not use one air and buy a 50 to 30 adapter.
But.........
Just because a pole has a 50 a 30 and 2 20 amp household plugs does not mean you have 120 amps available to pole.
You'd be lucky to have 70 available
Old 06-15-2012, 12:12 AM   #7
1l243's Avatar
If you have 50 amp and the park has only 30 amp, just run one AC but first you will need a 50 to 35 amp adapter and a 30 amp cord...
Mine looks like this
Park Power 50 Amp F to 30 Amp M RV Adapter - Adapters - Power Cords - Electrical
1l243 is offline   Reply With Quote
