Old 08-18-2013, 06:54 PM   #1
help with circuit
I'm having issues with a 2013 vengance 25v with 50 amp. Everytime i plug it to the genny it trips the breaker on the genny. I have everything off in the trailer it runs fine. Flip on just the ac and it comes on runs about a minute then kicks out. I have the 50 - 30 amp reducer to plug into the genny. I'm using a champion 4000/3500 with the 30amp rv plug built in. I Moved the genny to my buddies trailer it ran everything fine. Put 6500 on Mine same thing. My trailer is 1 week old. When I did my wall thru it was plugged into the wall at the dealers so everything was fine. Is there some stupid rookie mistake I'm making. Seen several people using this same genny go run their toyhaulers.
david155 is offline   Reply With Quote
Old 08-18-2013, 07:08 PM   #2
Always Learning
Do you have an EMS installed? If so, have you tried bypassing it?
Otherwise, I'd try to turn all of the breakers off inside of the camper and try the generator with no load and see what happens. Then them on one by one to see if you can isolate the problem.
Old 08-18-2013, 07:48 PM   #3
Don't want to sound stupids but don't know what ems is. I did not pull any f uses. I had all lights off the tv off the fridge off the ac off. I let the genny r un for about 5 minutes then turned just ac on. It took a few the it came on started blowing cold air for about a minute then click. Shut ev everything down moved my genny to buddies setup ran it fine. Tried my huge loud genny same thing.
Old 08-18-2013, 09:07 PM   #4
Always Learning
EMS like this - http://www.progressiveindustries.net/ems_hw50c.htm
But if you don't know, you likely don't have one.
Old 08-18-2013, 09:27 PM   #5
Lol yea I don't have that. Guess I'm headed back to rv lot for them to figure out
Old 08-18-2013, 09:32 PM   #6
Always Learning
Hopefully some other folks speak up- I really don't even know enough to be dangerous.
Old 08-18-2013, 09:59 PM   #7
You say you've turned everything off but unless you've done that by shutting off every one of the circuit breakers (except the two masters) then you haven't really done it. (In other words, you've probably forgotten something like the water heater or the converter.)
Old 08-19-2013, 06:57 AM   #8
Yes you are correct I didn't shut it off with the breakers. Is it normal to have to do that each time you fire it up? If so they didn't explain that they just said plug it in
Old 08-19-2013, 07:04 AM   #9
I think mostly you need to make sure the fridge and water heater are running on propane only as they can draw quite a bit of current. The converter can also be a bit of a load.
Filthy Beast is offline   Reply With Quote
Old 08-19-2013, 07:13 AM   #10
Herk7769's Avatar
Check to make sure you never run the water heater on electric when running on the generator.
Turn off climate control on your fridge (if possible).
Your generator should be able to handle the AC, but ONLY the AC.
A hard start capacitor and a fan delay relay will help reduce start up load.
Herk
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 08-19-2013, 07:14 AM   #11
avolnek's Avatar
if you have a 50 amp plug would that be due to a second air conditioning unit? If so are you running both of them? 30 amps will only power one unit generally... Sorry if you were already aware of this.
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 08-19-2013, 07:17 AM   #12
Herk7769's Avatar
He said he was using an adapter and I think that should only power one side of the panel. Can anyone who uses an adapter verify this?
Old 08-19-2013, 07:18 AM   #13
Ok yes the water heater is on auto so probably drawing electrity. The fridge I turned off on the fridge using just the off button it is a 50 amp in case I wanted to add second ac
Old 08-19-2013, 07:28 AM   #14
Should I flip off all breakers and then turn them on in a certain order as I'm using the generator if so how long should I wait before turning on and what can I run I would like to be able to run a couple of lights my radio and AC went on generator
Old 08-19-2013, 07:31 AM   #15
avolnek's Avatar
Turning off breakers isn't a bad idea... As to what you are able to run on your generator will be a camper to camper scenario... It will be different for most everyone... But you should be able to run the ac, lights and an outlet or two for little things shouldn't hurt anything... it will be a trial and error thing for you for a while...
Old 08-19-2013, 07:37 AM   #16
Herk7769's Avatar
David,
You are drawing too much current "as is" and we are trying to locate some high draw item that is overloading your generator when the compressor and fan are running as well.
ONLY by removing power to everything and then running JUST the air conditioner can we locate the current draw.
IF your generator can't handle the AC alone, it can be the problem.
I am NOT aware of ANY water heater that is "auto" as only the fridge has that kind of computer controlled source seeker.
IF your water heater is a Suburban you may have an AC switch OUTSIDE (small black switch) that controls the AC heating element.
Name:	Outside picture of Water Heater.jpg
Old 08-19-2013, 07:40 AM   #17
Is there a step-by-step procedure for starting up the RV on the generator or is it just start the generator then plug in the big table to the side of the RV and go
Old 08-19-2013, 07:40 AM   #18
dmf564's Avatar
If the water heater was on auto then yes it was running on electric. As it was said previously said make sure all of the appliances are off when you plug it in to your gen. Anything that will run on gas should be set to gas ( not auto ), I.e. your frig and water heater. Anything that has to produce heat is a huge current draw. So on start up, its all probably to much for your gen. Another thing to consider is if your gen. has an eco mode. Make sure that is turned off at start up. After everything is up and running then you can turn that on. As the amp demand on start up will often go up faster than the gen. can supply and will cause a breaker to trip. Its the overdraw protection on your gen. that causes that.
[SIGPIC]TV-2012 Ford F250 XLT Supercrew 4X4
TT- 2010 Jayco Jay Flight 17Z (traded)
TT- 2012 Coachman Catalina 30BHS (current)
Me and my wife with 3 kids love camping!!
dmf564 is offline   Reply With Quote
Old 08-19-2013, 07:42 AM   #19
Okay sorry I just saw that text post yes there is a small black switch outside by the element that lights the butane it says on or auto in off
Old 08-19-2013, 08:10 AM   #20
No particular order to turning the breakers back on except of course the AC first. After that, don't turn on anything you don't really need.
The small black switch outside turns on/off the electric heating element, not the propane.
Lou, a 30->50 adapter powers both legs of the 50 from the one leg of the 30.
