hello i am also new to the forum so if i mess up sorry in advance. i have a 2004 forest river explorer F275S the electric has been working we plugged up yesterday and no power does anyone have an idea what could be wrong i have checked the breakers and fuses whice appear to be ok also check supply and the plug works the air, microwave refridgerator no power
thanks for the headsup i will try to find the breaker the breakers on the panel
Your converter (makes DC for Bus) will be powered by 115 VAC circuit breaker. Its output is often protected by fuses at or close by the converter DC output. Still puzzeled by Microwave not working unless its broke also!
thanks the microwave was working but now my wife says the tv is not working from its outlet i have downloaded a converter manual from this site to try help all help is appreciated
Heres a photo of Buss fuses on rear of Parallax converter. Unit is sole occupant of a 20 amp breaker. Converter is rated 65 amp. Either fuse or breaker will shutdown DC
