Old 09-16-2012, 04:30 PM   #1
Help with no power
hello i am also new to the forum so if i mess up sorry in advance. i have a 2004 forest river explorer F275S the electric has been working we plugged up yesterday and no power does anyone have an idea what could be wrong i have checked the breakers and fuses whice appear to be ok also check supply and the plug works the air, microwave refridgerator no power
jeffro77 is offline   Reply With Quote
Old 09-16-2012, 05:35 PM   #2
Herk7769's Avatar
OK, when you say "no power" do you have lights?
Is all power gone or do you have AC (like air conditioning, microwave) or DC (like lighting and radio).
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 09-16-2012, 06:24 PM   #3
TURBS's Avatar
Which begs an answer of where you plugged into is there power there ?
Turbs
Old 09-16-2012, 06:40 PM   #4
no lights but electric outlet works in kitchen aarea
Old 09-16-2012, 06:43 PM   #5
no air or microwave also fridge not working on electric
Old 09-16-2012, 06:52 PM   #6
no power
i have a 30amp breaker on a 110 outlet i have 110 converterr plug with female rv plug its been working finr until yesterday
Old 09-16-2012, 07:43 PM   #7
Herk7769's Avatar
Your 120VAC to 12VDC converter is not working:
Reasons:
1) Your CONV breaker may be tripped in the power panel.
2) Your converter may be bad and not providing charging power
3) Because your converter is not working your battery is dead due to not being charged.
Old 09-16-2012, 07:49 PM   #8
no power
thanks for the headsup i will try to find the breaker the breakers on the panel
Old 09-16-2012, 07:55 PM   #9
Herk7769's Avatar
Yes. ONE of your 15 amp AC breakers powers your converter. It may be tripped.
Turn it off; then back on to reset it. It may have CONV on the legend.
Old 09-16-2012, 07:57 PM   #10
VinceU's Avatar
Your converter (makes DC for Bus) will be powered by 115 VAC circuit breaker. Its output is often protected by fuses at or close by the converter DC output. Still puzzeled by Microwave not working unless its broke also!
Old 09-16-2012, 08:22 PM   #11
no power
thanks the microwave was working but now my wife says the tv is not working from its outlet i have downloaded a converter manual from this site to try help all help is appreciated
Old 09-16-2012, 08:23 PM   #12
bob213's Avatar
Have you checked the GFI Outlet?
bob213 is offline   Reply With Quote
Old 09-16-2012, 08:31 PM   #13
no power
yes sir i checked that i learned a lesson in my home after calling an electrian out wont forget it after paying the bill for him to push the button
Old 09-17-2012, 10:06 AM   #14
Herk7769's Avatar
Sounds like the breaker in the power center (that powers the converter and the string of outlets your TV is on) is tripped.
Old 09-17-2012, 11:38 AM   #15
VinceU's Avatar
Heres a photo of Buss fuses on rear of Parallax converter. Unit is sole occupant of a 20 amp breaker. Converter is rated 65 amp. Either fuse or breaker will shutdown DC
