Old 05-30-2017, 04:43 PM   #11
Converter/charger
Your problem is in the converter/ Charger!
When the charger is charging the battery or supply the 12 volt to your TT.
The converter transformer make that noize also they add ferite beads to the diodes and that can also vibrate and make the noize .
It can be fix by an electronic tech. Not a big job!
Jonol is offline   Reply With Quote
Old 05-30-2017, 04:45 PM   #12
Sorry, I had to do it. It just leaped into my mind when I read the original title. https://youtu.be/STNrDw8qpag
"Lord, forgive me for what i done right there..."
hankpac is offline   Reply With Quote
Old 05-30-2017, 04:48 PM   #13
MartiB's Avatar
Originally Posted by Tankmaster View Post
I just picked up my 2018 Forest River Hyper Lite 30HDS about a month ago. I noticed that high pitched noise you mentioned. I only notice it when I turn on the bathroom light.
I've noticed my 2015 Salem CruiseLite has a hum coming from the fuse box area but only when more than one light is turned on.
Marti
2015 Salem CruiseLite 241QBXL
2016 Nights Camped: 30
2015 Nights Camped: 17
MartiB is offline   Reply With Quote
Old 05-30-2017, 08:16 PM   #14
Sounds like the converter fan / bearing noise.
Replace Fan.
mfMcFroggierPod is offline   Reply With Quote
Old 05-30-2017, 08:25 PM   #15
Kathy T.'s Avatar
Kathy T. is offline   Reply With Quote
Old 05-31-2017, 07:47 AM   #16
I just picked up my 2018 Forest River Hyper Lite 30HDS about a month ago. I noticed that high pitched noise you mentioned. I only notice it when I turn on the bathroom light. I know that it's not an exhaust fan it comes from the fuse panel. It will run a little then stop. I hope it's not a bad converter already. Waiting on Forest River to answer. Anyone have this problem too?
Thanks everyone for your feedback on this issue. Sounds like everyone has the same conclusions about the noise. I just don't want to be stranded with no electricity lol. All the dealers are booked up till July 10 I have another issue the brakes so I have a quick stop in and they will look at it. Safety first so hopefully they can hear the fan and fix it or order one. Thanks more to follow
Tankmaster is offline   Reply With Quote
Old 06-01-2017, 07:01 PM   #17
Originally Posted by ColoradoRick View Post
I was, also, thinking it's just your power convertor. When mine gets a certain load on it (like having a lot of lights on and then turning on my coffee maker) the convertor will make a noise and the cooling fan inside also comes on.
The reason is it has to convert the 110 shore power (or 30 or 50 amps) down to 12-volts which is what most things the camper runs on.
Thanks for your feedback that's what dealer told me today.
light, noise
