I just purchased a new Honda- Also got a dog bone to convert twist lock to 50amp rv. I screwed up and fired up both AC on this outlet now the outlet only has voltage at one of the leg at the generator, is there a way to reset? I tried the circuit breaker switch but still only has voltage one 1 leg.
Should have breakers near the receptacles. Nevermind, I believe you tried that. Does it lack a leg at the generator receptacle or the bone receptacle? If generator, it has an internal issue. If bone, replace bone.
