09-30-2017, 06:59 PM
Honda Gen causes Surge Protector to reset
I have a 2011 - FR Sierra 5th wheel,Surge Guard 50 Amp, Hardwired, and Honda e2000 generator.
When on house or shore power no issues. But ifbatteries are SOC of 80% I hook up the Honda.
They have tendency to keep cycling the surge guard protector, which is hardwired. The panel says that low volts.
What a pain.
Can I get suggestions on how to remedy?
I am about ready to remove the surge protector.
2011 5thWheel Sierra
F250 Ford 2008 Diesel
Larry & Sharon
09-30-2017, 07:31 PM
Who Dares, Wins
You usually need to bypass the EMS with a geni because it will read as an open ground and shut off without making the plug thing.
2015 Chevy HD D-Max
2022 Impression 315MB
10-01-2017, 12:33 PM
Doc73,
How do I bypass the EMS?
Should I remove the hard wired unit and go with a plug model? That would take the whole EMS out of equation.
Larry & Sharon
10-01-2017, 12:49 PM
Who Dares, Wins
If it's hardwired read the manual because I think it tell you how to bypass it. I have a plug in model and just do not use it with the geni.
2015 Chevy HD D-Max
10-01-2017, 03:00 PM
The voltage is dropping below 102 V causing the surge protector to cycle. Make sure there is nothing else using AC (only the converter) when trying to charge the batteries.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
10-01-2017, 04:09 PM
Doc73
Good advice and guidance.
Happy trails to you!
Larry & Sharon
10-01-2017, 04:24 PM
Who Dares, Wins
If you want to avoid the bypassing each time (if that was the issue) check out the Google to make the grounding plug. You plug it into the geni and it solves the open ground issues. I think it is a wire from. The ground to the neutral but CONFIRM.
2015 Chevy HD D-Max
10-01-2017, 04:34 PM
He has low voltage issues (per his codes), that has nothing to with the ground issue. He needs to put a volt meter on the genny with no load and again with a load. Check the amperage, it may be overloaded.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
10-01-2017, 04:38 PM
One thing I neglect to mention is I have a MAGNUM unit to charge battlers and provide AC.
could it be that the Magnum is pulling too many amps to charge batteries?
Larry & Sharon
10-01-2017, 04:39 PM
AC is not air conditioner.
But alternating current.
Larry & Sharon
10-01-2017, 04:42 PM
It could be. How many amps on the generator load?
Andersen hitch
10-01-2017, 04:44 PM
BINGO!
10-01-2017, 05:04 PM
Who Dares, Wins
Yeah not going to be able to run everything off the eu2000. Especially 50 amp services.
2015 Chevy HD D-Max
10-02-2017, 01:54 PM
My Honda eU2000i trips on over current
My Honda generator trips when overloaded and doesn't provide any power. The Fault indicator comes on and won't reset without a shutdown and a restart.
A voltmeter at the generator will tell what is happening. Couple that with a voltmeter at the AC outlets in the coach. Harbor Freight VOMs are free with a coupon and a small purchase. I have a stack of them and carry one in the truck and the trailer. For good work I have two other meters that are bench top models but the HF meters are good enough for a quick check.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
10-02-2017, 02:05 PM
brother-in-law had a similar problem this past weekend with his Kingston 5er. When running his 4000W Champion gen none of his ground fault receptacles would work. He Grounded the gen and that didn't help. Any ideas?
Steve & Cody the Wonder Dog (he wonders if he is a dog or not)
Forest River - Rockwood
2018 Ultra Lite 2040WS 5th wh
2020 Ram 1500 Eco Diesel Curt Hitch - 392 rear end
10-02-2017, 02:28 PM
Grounded the generator how?
Did he have the Edison plug that bonds the ground & neutral?
10-02-2017, 02:39 PM
I have seen 17amps draw when the Magnum is charging the batteries.
I never run air conf if charging batteries.
Larry & Sharon
10-02-2017, 03:58 PM
You are overloading your generator, pulling 17 amps is 2040 watts. It's only rated for 1600 watts.
Joe
2015 Wildwood 27RKSS (now sold)
2015 Silverado 2500HD Duramax
10-02-2017, 04:54 PM
You don't say which magnum and how many amps. 100 amps would require about 1200 watts well within the Honda's ability. With not much of anything else powered.; assuming the batteries and charger are in Bulk mode. Keep in mind when on generator besides charging it's trying to power anything 120 vac that's on. To prevent open ground fault (not what you arr seeing) make a plug that ties neutral to protection ground like was suggested. You also need to consider with the Honda you will only have probably L1. It could take a combination of adapters to get a 50 amp EMS to be happy with 15 amps on one leg.
10-02-2017, 10:02 PM
I have a Generac inverter generator. When I couldn't get any power to my TT with my Surge Protector plugged in I called Generac and was told I could not use surge protectors on generators, I believe because of the lack of grounding.
