Old 08-19-2016, 05:53 AM   #11
Here's what it does on my Honda generator
Originally Posted by nso4life View Post
I didn't intend on running all of my components. Just the necessities. What exactly does the 240 switch do?
It provides a voltage output of 120 volts each on the two hot legs on the 4 pole receptacle - two hots, one neutral and one ground.
It does not change the total output capacity (watts) of the generator.
If the adapter you are using ties the one hot leg of the 30 amp output to both hot legs of the trailer input, then the result should be the same - both legs of your CB panel are powered.
An air conditioner will draw about 15 amps or so. My 15K btu A/C runs fine on the 3200 watt diesel generator on my RV - smaller generator than you have. We can also run limited other items. Whoever said your generator is useless is misinformed.
KatanaPilot is offline   Reply With Quote
Old 08-19-2016, 06:16 AM   #12
Georgia Frog Rally 2017
aceinspp's Avatar
I run a 3600SI Boliy running my 15000 btu ac no problem. Your not going to run much else tho. Yours is fine for your intended purpose. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 08-19-2016, 06:23 AM   #13
Sorry, but I made one major mistake in my previous post. The situation is even worse than I first though and IF you want to actually use this for partial power, YOU leave the switch in the 120 volt position and use RECEPTACLE NUMBER 1. you will have 4000 watts of capacity on a 30 amp 120 volt TWIST LOCK RECEPTACLE
The following trys to explain how your generator switches work and the capacities for each receptacle depending on switch postion
You have a two position switch "120 volts" and "120/240 volts"
In the 120 volt position, the receptacles are from LEFT TO RIGHT
1- 30 amp at 120 volt TWIST LOCK RECEPTACLE
2- 20 amp at 120 volt DUPLEX RECEPTACLE
3- 20 amp at 120 volt DUPLEX RECEPTACLE
4A - 20 amp at 120 volt USING HALF OF THE 4 wire 120/240 volt TWIST LOCK RECEPTACLE
this receptacle is wired for dual purpose so
4B - NO POWER
IN the 120/240 position, the receptacles are from LEFT TO RIGHT
1- 15 amp 120 volt capacity on a 30 amp TWIST LOCK RECEPTACLE
2- 15 amp at 120 volt DUPLEX RECEPTACLE
3- 15 amp at 120 volt DUPLEX RECEPTACLE
4A and 4B - 15 amp at 240 volts on a 4 wire TWIST LOCK RECEPTACLE
The twist lock on the right is DUAL WIRED and CONTROLLED BY THE SWITCH
It is wired so that then the switch is in the 120 volt position, you are using one hot wire, which they call "4A", the nuetral, and ground, which provides you with 20 amps @120 volts in a TWIST LOCK CONFIGURATION
When the switch is in the 120/240 volt position, The receptacle that they call "4A-4B" is wired with TWO HOT WIRES and a GROUND giving you STRAIGHT 240 VOLTS @ 15 AMPS
In order to even use "4A/4B" you would need specialty adapters, which you should have been provided along with which one to use in each switch postion
I really don't know how to be much clearer on the bill of goods you were sold but I wouldn't even attempt to rewire this generator to work with a 120/240 volt RV SYSTEM.
sorry for your loss, and good luck
ShermanD is offline   Reply With Quote
Old 08-19-2016, 06:29 AM   #14
Originally Posted by boondocking View Post
You are not going to gain anything by using the 240v with the proper adapter.
The 120v will supply 29.2 amps and the 240v will supply 14.6 amps, so you gain nothing.
Does it matter if I use the 30 amp plug on the left or the 20 amp on the right?
nso4life is offline   Reply With Quote
Old 08-19-2016, 06:30 AM   #15
Stay at a Holiday Inn Express last night?
Wow, don't know where to begin.
240 volt output from a generator like this comes from connection to both hot legs - not from either one individually. The output from either leg is 120 volts.
If you have a 50 amp/240 volt trailer, you have a CB panel with two hots, one neutral and one ground. Each of the hot legs is 120 volts - the same as the output of the generator and the same as the output from a 50 amp receptacle at a campsite.
Appliances that use 240 volts will have a two pole breaker - 120+120=240.
My comments about Holiday Inn Express were not directed at the OP, BTW.
Even your home appliances like your dryer, range, etc. get 240 volts from having two 120 volt legs (they are out of phase). Take your volt meter and check - hot to neutral (or ground) - 120 volts. Hot leg to hot leg - 240 volts.
Old 08-19-2016, 06:34 AM   #16
4B - NO POWER
VERY HELPFUL! Exact answers I needed. Thank you.
Old 08-19-2016, 06:36 AM   #17
Thank you all. Got the info I need.
Old 08-19-2016, 07:25 AM   #18
SeaDog's Avatar
This is the same type of generator I used in my construction business, you will get you most power by using a 30 amp twist lock to residential and then a 30 to 50 with residential adapter. It will limit some of the equipment you can run but with a little careful planning I doubt will have any problems.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 08-19-2016, 09:39 AM   #19
Thank you.
Old 08-19-2016, 10:04 AM   #20
Herk7769's Avatar
To sum up, specifically for your generator model.
If you use the "120 volt switch setting" socket 1 will provide 30 amps of 120 volt power and you will need a 3 blade round locking plug to 30 amp adapter (available) AND a 30 amp Male to 50 amp RV socket adapter to use it (you should have one in your kit anyway!). The adapter will provide a total of 30 amps to both "legs" split as needed but you will need to monitor your usage to make sure you don't exceed 30 amps of TOTAL power in your coach. You can use the rear AC, but not the front (or vice versa for example). Another example is to use the microwave you will need to shut off both ACs while using it on your generator. The spike on compressor startup will kick your generator off line.
https://www.amazon.com/Arcon-14398-G.../dp/B000RUQN22
https://www.amazon.com/Arcon-14014-G...50+amp+adapter
If you use the "240 volt switch setting" you should use socket 4 (the 4 bladed one). This socket provides an available 15 amps to each leg maximum. You will need to buy a 4 blade round locking plug to 50 amp RV socket adapter to use it.
https://www.amazon.com/Camco-55422-P...50+amp+adapter
While you may think this is the same 30 amps total; it is not.
Using socket 1 and the 120 volt setting, you could power your coach with 20 amps on the A leg and 10 amps on the B leg and your generator will be happy. If you did that using the 240 socket, the overcurrent on leg A would trip both breakers in your generator.
Hope that helps...
HAM CALLSIGN - KC3FFW
generator, switch
