Old 05-01-2016, 02:39 PM   #1
Send a message via AIM to NoviBill
House lights not running off of engine battery - Battery not charging
I have a 2006 Lexington 255DS MH and the house battery has never charged off of the engine. My first guess is the charging relay is shot (see photo). I will replace that this week.
2nd issue, stupid error on my part (I think). The coach lights would work whenever the engine was running with to coach battery disconnected. Well not thinking i tried to start the generator and all the lights went out. Connected the coach battery and the lights worked and the generator started.
I looked for a blown fuse or relay and found nothing.
Any guess what failed?
Thanks,
Bill
Battery charging relay - Lexington 255DS 2006 by cdrdwd, on Flickr
Bill & Renee from Novi, Michigan
http://anunbalancedbalance.blogspot.com/
NoviBill is offline   Reply With Quote
Old 05-01-2016, 05:53 PM   #2
good looking solenoid! Replace that first and see what happens. I think that you can start the genny with the batteries disconnected, but the converter on my unit won't do much in that circumstance.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 05-21-2016, 10:19 PM   #3
Scott,
You were spot on. Replaced the charging solenoid (after pulling everything out and painting the batter box) and it works great.
Thank you!
battery, charging, light
