Old 05-22-2016, 09:53 PM   #1
How long will the battery last using a 12 volt fan?
We just got our first camper and i have lots of questions. First one is can I run a fan (12 volt type) through the tv/antenna jack that has a cigarette type outlet? Also about how long do you think it would last?
tiffu22 is offline   Reply With Quote
Old 05-22-2016, 11:41 PM   #2
Please google 12volt side of life. It'll educate you about wattage and its mathematical relationship to voltage and current.
Fan question: How many amp-hrs or watts does this device consumer?
That will determine if a cig lighter plug will work. It probably will but bigger question is how long before you hit 50% depth of discharge so you can recharge again.
Skyliner is offline   Reply With Quote
Old 05-23-2016, 12:17 AM   #3
A typical 12v RV fan will draw between 400-500 ma. So you can plug it into a cig type outlet, most 12v RV fans already come with that type plug. If you use the upper 500ma (1/2 amp) draw for your calculation, the fan will use 1 AH (amp hour) of power every 2 hours.
If you have a typical single battery that came with the camper it is more than likely about 80-90 AH, of which 40-45 AH is usable before you need to re-charge the battery.
How long you can run the fan depends on how much power you draw from all other sources, lights, furnace, CO detector etc.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
12 volt, battery, fan
