Old 03-08-2017, 12:03 PM   #1
muddyrode's Avatar
How many AMPs are you drawing
Has anybody actually put an AMP meter on the service circuit to see what there unit is actually drawing
just out of curiosity
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 03-08-2017, 12:09 PM   #2
Flybob's Avatar
Many members have Progressive EMS units on their service connection. Most all of them provide both voltage an current however it continually changes as items are turned on and off.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-08-2017, 12:18 PM   #3
World Wide Wanderer
wahoonc's Avatar
Yup... more than 30 if I try to run too much at once.
I have the readout on my EMS and I have a clamp on ammeter. I know my water heater draws 12 or so, fridge is 3, converter is 0-12 depending on battery depletion. Someone posted a table or chart with the various draws measured out on it.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
Old 03-10-2017, 12:07 AM   #4
I just upgraded my 30 Amp 120 Volt RV to 50 Amp 220 Volt service. I added two $15 meters off Amazon to show the actual load of everything that is drawing power from both legs of the power feed. I mounted them in available space in a kitchen wall. Very interesting to see just exactly what everything is drawing in real time without going outside to look at a surge protector Click image for larger version
Netcomdude is offline   Reply With Quote
Old 03-10-2017, 02:44 PM   #5
Full-Timer
Could you give us a link to that meter on Amazon?
Thanks!
Drew & Micki V. - Full-Time Since 2001
2006 Forest River Sandpiper Sport SP34T
1982 GMC C3500 3+3 Camper Special w/modified 7.4L
1976 Holiday Rambler Presidential 3300 TT (still roadworthy... just in case)
1984 Chevy K2500 Suburban (just in case)
DesertDrew is offline   Reply With Quote
Old 03-10-2017, 07:14 PM   #6
D W
D W's Avatar
Aaron
Reminds me the GREEN ACRES Episode "You Can't Plug In A 2 With A 6". Hilarious, but so true.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 03-10-2017, 07:39 PM   #7
Dahagen
Is muddy talking about 12 volts or 120 volts? For 120 volts most appliances and other devises have a plate listing the draw of the unit. Add 'em up. For 12 volts, hook an ammeter into the hot (+) lead.
dahagen is offline   Reply With Quote
Old 03-10-2017, 07:59 PM   #8
davel1971's Avatar
https://www.amazon.com/bayite-BAYITE...QKD7VBQXHDF1KS
David & Lynn
Old 03-10-2017, 08:16 PM   #9
World Wide Wanderer
wahoonc's Avatar
I have lived in a few places like that...
With a 30 amp system like many RV's have you do have to do some power management. Like no Keurig and blow dryer at the same time.
aaron
Aaron & Rhonda
Old 03-10-2017, 08:26 PM   #10
davel1971's Avatar
Originally Posted by Flybob View Post
Link is to 12V DC meter. One in post is 110AC
I posted wrong one at first. I changed the link to correct it.
David & Lynn
