Originally Posted by Duckogram
Be careful, you may have 4 x 6 volt batteries. Putting a 12v charger on one battery would be bad.
VERY TRUE. You have to see what you have. It may be 4 12v batteries in parallel or 2 pairs of 6v batteries. They will be two in series tied to two more in series by linking them in parallel. Usually charging one 12v or pair of 6s will charge the others but BE SURE TO LOOK AND KNOW WHAT YOU HAVE BEFORE YOU DO ANYTHING.
I disagree with some above. If you are staying off connections at camp and have to charge once or twice a day with the generator, a separate battery charger at the same time that the converter is charging and you can shorten the necessary generator time.
If I had a residential frig, I'd be looking for a convenient way to install two more batteries.
Oh, and goes without saying, a solar sytem, of at least 100 watts per battery.
Lots of good links on the forum and YouTube about battery condition meters, charging, solar and general battery use n maintenance.
Good luck. Enjoy.
