Old 05-18-2013, 10:12 PM   #1
How to check a converter?
Through a dumb mistake of my own while wiring in my PI power protector, I managed to mislabel one of my hot legs and my neutral and managed to provide half my Sabre with 240 volts in the breaker panel. I had a roll of 6AWG wire and was just using that wire and taping the ends in different colors (eg white, green, etc.) to note the difference. Apparently when I was cutting wire to length I wasn't paying attention and labeled my hot leg white rather than black. I guess that is what happens when you try to be frugal.
It zapped the TV, but otherwise seemed to miss most everything else. That being said, the only thing I am not sure about is the ac - dc converter. Any ideas on how I can check it out to make sure it is still OK?
By the way, what is the breaker marked "GEN"? I don't have a generator which would have been my first guess.
2012 Palomino Sabre 32BHTS
2008 GMC Sierra 2500 SLE 4x4 Duramax
clange is offline   Reply With Quote
Old 05-18-2013, 10:31 PM   #2
TURBS's Avatar
http://www.forestriverforums.com/for...?do=file&id=24
Here you'll find troubleshooting info.
You should have a wfco 8955.
Old 05-18-2013, 10:33 PM   #3
TURBS's Avatar
Gen thread.
breaker panel "GEN"?
Old 05-18-2013, 10:44 PM   #4
Thanks again, Turbo. In looking at the tests for the converter, if I just check the dc voltage test wouldn't that likely suffice to tell if the converter is ok? If not maybe go through the rest of the tests?
I just keep kicking myself for something so stupid!
Old 05-18-2013, 10:47 PM   #5
TURBS's Avatar
you should have atleast 13 v output.
It happens !
