Old 07-08-2015, 07:01 PM   #1
How to convert 50A receptacle to 30A
I bought a house with a 50A 240 receptacle on the wall in the garage. I want to convert it for use with my motorhome which is 30 amp. Is there a converter cord or do I need to change out the wall plug to 30A? And then there is the breaker in the panel which is a problem. Its a two pole 40A each, 240Volt.
Got ideas.
Doug Michaels
2015 Solera 24W
Three big dogs
One wife
Two kayaks, One SUP
Bend, Oregon
Solera is offline   Reply With Quote
Old 07-08-2015, 07:46 PM   #2
Left Coast
There are ready-made adaptors......you should be able to find there in Bend. Also, the plug (50 amp) 240 volt can be re-wired to 120 volt. Is that breaker you've got a side by breaker...if so, get a 30 amp side by side
Old 07-08-2015, 08:18 PM   #3
TURBS's Avatar
When done you should have one hot one ground and one neutral.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-08-2015, 08:26 PM   #4
Mr. Dan's Avatar
Why would you need a 30 amp side-by-side? I think you need a single pole 30 amp for the single hot. All the 30 amp RV plugs I've ever seen are single pole.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 07-08-2015, 08:30 PM   #5
Left Coast
Just so there wouldn't be an empty hole in panel......and you couldn't test for power the redneck way!
Old 07-08-2015, 09:23 PM   #6
Mr. Dan's Avatar
OK, but here's hoping the OP doesn't insert a ground or neutral/common wire in that second slot!
Old 07-08-2015, 09:40 PM   #7
dannyabear's Avatar
All you need to do is plug in a 50 to 30amp dogbone. End of story.....
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 07-08-2015, 09:41 PM   #8
fast murray's Avatar
Just get a 50 to 30 amp RV adaptor. The motorhome will have a 30 amp main breaker to protect the interior wiring.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 07-08-2015, 09:48 PM   #9
mikkeeh's Avatar
NO..NO..NO His outlet is wired 240V. The breaker needs to be changed to 120V......and the outlet rewired. You cant plug an RV into a 240V outlet!!!!
Well I guess you can...but only ONCE.
mikkeeh is online now   Reply With Quote
Old 07-08-2015, 09:56 PM   #10
Every 50 amp receptacle intended for an RV is wired for 240 volts. It will be a 4 wire receptacle with two phase conductors a neutral and a ground. 120 volts from each phase to neutral and ground and 240 volts phase to phase. The dog bone adapter from 50 amp to 30 amp will only connect to one phase, the neutral and the ground. If the 50 amp is not a 4 wire receptacle then most likely it is two phases and ground without a neutral. The dog bone will not be the right configuration to plug into it.
WY Husker Fan is offline   Reply With Quote
