Old 10-31-2015, 12:23 PM   #1
MSB68's Avatar
Question How to Disconnect House Batteries
You would think I would remember after all these years, but I forgot! What is the sequence used to disconnect the house batteries? I can't remember if you disconnect the negative sides first, or the positive sides first. I will be storing them in my garage and using a Battery Minder on them for the winter.
Mike & Sherry
2015 Georgetown 329
Toad: 2014 Honda CRV EX-L
Days Camped 2017 = 56
Days Camped 2018 = 74
MSB68 is offline   Reply With Quote
Old 10-31-2015, 12:47 PM   #2
Hutch333id's Avatar
Negative side first.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 10-31-2015, 12:49 PM   #3
Professional Texan
TexasBob's Avatar
X2
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 10-31-2015, 01:02 PM   #4
From an electrical point of view, it doesn't matter.
From a safety point of view, some say to remove the negative first since the negative side is grounded to the chassis. This avoids, while removing the positive lead, your metal wrench contacting a portion of metal (not the other battery post) that is grounded to the negative post, creating a major sparks shower.
I personally don't worry about the order too much from having worked on live circuits (usually more than 12V). I just make sure the end of my wrench and my hand do not touch other metal (including the other live terminal, which is usually the easiest thing to touch inadvertently) while removing wires.
Fred W
2014 Rockwood A122 (A-frame)
2008 Hyundai Entourage (minivan)
Old 10-31-2015, 01:14 PM   #5
Ford Idaho's Avatar
" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
The 12volt Side of Life (Part 1)
Negative connector first and last.
Old 11-01-2015, 12:56 PM   #6
X3
Sometimes you wind up working on a hot circuit. For example, you might wire in a charger and not be bothered (perhaps foolishly) to disconnect all of the grounds from the batteries.
So, I just take the added precaution of wearing gloves to insulate my hand, particularly my ring fingers, in case I make a mistake.
gordonsick is offline   Reply With Quote
Old 11-01-2015, 02:16 PM   #7
If you leave the house cables loose and there's any chance you will start your Georgetown, tape up the positive cable terminals. When you run the chassis engine the battery control center will energize the relay that connects the chassis battery and the coach batteries. If one of the positive cable terminals touches metal it will be grounded and you will at least get a spark. Damage could result.
The same thing could happen if you plug in to shore power. The convertor will send 12 volts to the coach battery cables.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 11-01-2015, 05:57 PM   #8
I never use a wrench to remove battery cables. I use a socket and a composite socket driver from HFT. No chance of shorting anything out.
Phil
pmsherman is offline   Reply With Quote
Old 11-01-2015, 06:25 PM   #9
Roger and Paula
Put a disconnect switch in line. That way you don't have to deal with removing battery cables.
Rstrahan is offline   Reply With Quote
Old 11-01-2015, 06:38 PM   #10
Bluepill's Avatar
I also always try to use a wrench that is shorter than the distance between the battery terminals.
Don't ask why....................
And you don't want to see this........................
Old 11-02-2015, 08:16 AM   #11
muddyrode's Avatar
it is safer to disconnect the negative first but does not rally matter as far as the components themself i have been the telephone switch business for 32 years working with DC power, as a lot of work is done with live current you have to watch out or you can do some welding
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 11-02-2015, 09:31 AM   #12
Wolverine 1945's Avatar
WOW !!!
That is one HOT nut !!!
Wolverine 1945 is offline   Reply With Quote
Old 11-02-2015, 10:59 AM   #13
crazy putting the neg and pos les than 1/2 inch apart. That would be a fire waiting to happen.
j free is offline   Reply With Quote
battery
