Old 11-01-2012, 05:17 PM   #1
(Kim)
Labzy's Avatar
How to prevent battery wire ends from oxidizing
Last time I went to the storage unit to pick up the TT the battery wire ends were oxidized and the power jack would not work; the only useful thing I had on hand to clean them off with was an emery board
What is a good way to prevent this in the future?
Do you coat them with some type of lubricant?
Thanks!
Kim
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 11-01-2012, 05:36 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
KY or petroleum jelly is one cheep and usefull way. Their is a spray, red.... I think, but why pay more? All your doing is preventing the oxidation or blocking the oxygen from interacting with corrosion.
donanddona is offline   Reply With Quote
Old 11-01-2012, 06:29 PM   #3
Lynkage's Avatar
KY or PJ or any grease will work fine. The spray does not work.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 11-01-2012, 07:18 PM   #4
First you have to get rid of the acid that may be on and around the terminal. Just put water all over and use baking soda powder and sprinkle over the terminal. If acid is present it will bubble and neutralize the acid.
Wash is off after the bubling action stops the put some patrolium prododuct onthe actual terminal.
Good luck
Old 11-01-2012, 07:50 PM   #5
Bennington Camper's Avatar
I've used wheel bearing grease for years as well as petroleum jelly to coat battery and wiring terminals with great success.
Dont' think KY would be a good choice only because of its water solueability.
Be sure all traces of acid are cleaned off the terminals by dipping ends in a bath of baking soda and water. Sometimes I use an old toothbrush to work it into the cracks. Flus and repeat until no more foaming/bubbling.
Dry completely, clean thouroughly with wire brush, then using a glove or paper towel, apply thouroughly to parts.
In my solar business, I heat petroleum jelly in a used can with a heat gun until it is liquified, then dip the cable ends into the can for best flow into nooks and crannies.
-Glenn
Glenn - KA2DTH
2007 Chevy Express 1500 AWD
2005 Surveyor SV-230
Bennington Camper is offline   Reply With Quote
Old 11-01-2012, 08:10 PM   #6
dfskinner's Avatar
Labzy the red stuff in the cans works really well........
I have a different question; you mentioned using the "Power Jack" with the battery?
My power jack does't seem to work with the batter? Am I missing something?
dfskinner is offline   Reply With Quote
Old 11-01-2012, 08:11 PM   #7
WestCoastRV'er's Avatar
Battery Di-Electric grease
You can get battery terminal Di-Electric grease at any auto parts store where they sell batteries. Cost is around $1 per pack.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 11-01-2012, 08:22 PM   #8
Lynkage's Avatar
I never thought about it being WS so yeah not as good. Thanks for the lookin out!
-Glenn
That is a good idea!
I also heat the wire if possible so the grease flows like solder.
Shane & Antoinette
Old 11-01-2012, 09:02 PM   #9
K-Y Intense Arousal Gel? Is this what you mean?
Old 11-01-2012, 09:15 PM   #10
B47
You are gonna get kicked off this forum with stuff like that.
Old 11-01-2012, 09:53 PM   #11
Twisty's Avatar
Well played my friend, well played.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
battery
