Old 09-17-2014, 05:17 PM   #31
Kaadk's Avatar
Originally Posted by campnqueen View Post
They cut the battery cable to steal our battery. JERKS! Now we have to replace the battery cables.
Is this the same one they stole a couple weeks ago or did they steal it again?
Btw, did you get a chance to trace the lines and see how long of a cable you'll need? We're still waiting on the other thread to hear back on that.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 09-17-2014, 07:45 PM   #32
RPAspey's Avatar
Originally Posted by OldCoot View Post
Not hard for me, I have a vertical metal band saw and a horizontal metal band saw and a metal cutting lathe. They neither one get as tired as a hacksaw.
It will take at least 15 minutes with a good blade in a hacksaw as the shank is usually 1" diameter.
Took about 25 mins to cut and tap. I use the eye bolt to grab the greasy ball.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 11-20-2014, 08:22 AM   #33
mark0224's Avatar
If it was in a secure storage area it had to be somebody that either worked there or another person storing there, your not going to hike a battery over a fenced in area. Any padlock you put on can be cut off with a good set of bolt cutters , if they had enough time to get a battery unhooked the few extra seconds to cut a lock isn't going to bother them. Surprised they didn't take the propane tanks and the spare tire too a real criminal would have gone for everything they can get and the other trailers would have been victims too.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 11-20-2014, 07:18 PM   #34
That cut-off ball won't stop anything. They'll just back up to it, wrap a heavy chain around the tongue and their hitch, and drive off somewhere they can take their time.
Another idea that won't stop anyone but might help is to wrap a chain through a wheel and then around the axle. Likely they'll miss it at first until they drive off and the tire starts to squeal loudly. They might then just drop it and run.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
battery
