Old 07-27-2016, 08:02 AM   #1
How to test class a converter
Is there a way to determine if converter is defective other than batteries not charging? Any way to verify output?
dtuten is offline   Reply With Quote
Old 07-27-2016, 08:21 AM   #2
WolfWhistle's Avatar
plug into shore power while batteries are disconnected and see if 12volt things work? Volt meter?
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
WolfWhistle is online now   Reply With Quote
Old 07-27-2016, 09:58 AM   #3
Head Rambler
You could also test the voltage out of the converter. It should read greater than 12.7v.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-28-2016, 07:47 AM   #4
Herk7769's Avatar
It is VERY important to disconnect the negative post battery cable when doing converter tests. A damaged battery (or one that is discharged DEAD) will prevent the converter from powering up to protect the converter from damage.
I would also check the battery reverse connection protection in the power center. My converter has 2 40 amps orange fuses that WILL blow if the battery cables are hooked up backwards even momentarily.
I have also attached the WFCO 8900 series troubleshooting and repair guide that might help even if you have a different model.
Name:	30 amp panel.jpg
ID:	115605   Click image for larger version
HAM CALLSIGN - KC3FFW
class a, converter
