Originally Posted by BamaBob
Actually, the Autoformer comes from the factory as a portable unit. You have to purchase a wiring harness to permanently install it.
Maybe you can consider permanently installing the Autoformer, plug it into the (portable) Progressive EMS, leave the Progressive EMS in your bay with the Autoformer and run your 50(30)AMP cable to the pedestal?
Hmmmmm...............
Is that the Georgia education or the Alabama environment?
I need to think that one through. The shelf I have in mind already has the inverter on it. I'll have to measure to rearrange. But you may be onto something.
EDIT: One reason (among others) that I like the portable EMS is to plug it into pedestal first........before plugging anything else. Then read what's what before plugging up. This would sort of eliminate that. Or not..........maybe. Maybe not.
Thinking. Hard for me today.........have other major trailer issues.
Double EDIT: The problem would be getting the anaconda 50 amp cable out of that door and into the receptacle on side of trailer 20 feet away. I
I think I'm back to square one.
