Old 03-09-2013, 03:55 PM   #11
Indymule's Avatar
Melting the hole!
That's a good idea I would not have thought of.
Makes sense, I guess that's why I wouldn't think of it.
I'll give it a try!
Jay & Maria - Camp Dogs Jackson & Joplin
2015 Rockwood 2604WS Emerald
Hensley Arrow hitch
2015 Ford F350 Crewcab Lariat Diesel
Indymule is offline   Reply With Quote
Old 03-09-2013, 04:15 PM   #12
WolfWhistle's Avatar
Originally Posted by DAISY BOYKIN View Post
I don't think waterproof, no waterproof, 1000 lights would have made any
difference when the Expedition hit me!
Take a look and see what you think? Oh, he missed one of the lights! WOW, can't believe one light survived.
Believe it or not, a 1996 ford Expedition will fit inside a 26' Flagstaff, well almost.
No, he was not texting!
Lucy.... I'm home!
Looks like it time for a few upgrades, starting with a very heavy and large back bumper!
Oh... about the drain holes... I popped off the lenses (which we know can be cracked while drilling) one at a time and instead of drilling the lense, I drilled from the inside out, on both bottom corners of each lens. The white plastic base is not prone to cracking like the lens. You just have to be careful to not let the drill hit the trailers skin... lean the drill motor as vertical as possible and drill slowly. I didn't have a trace of water, only dust. The battery box already had drain holes from the factory... I think the brand is NOCO... yea! and American Company in Indiana! Buy American when you can!
Melting the holes is a good idea. I think I read this in Mechanic Illustrated several years back, but had forgotten it. The wonderful thing about getting old is you meet new friends every day!
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 03-09-2013, 05:53 PM   #13
kz08h5's Avatar
I check one of my rear clearance lights late last summer because it wasn't working. I could not believe my eyes. The lenses just snap in place. There is nothing to keep moisture out. There was enough corrosion make all the rear clearance lights intermitent. To make matters worse, I didn't get one of the lense covers snapped back on correctly and it came off in transit. So now the To Do list is changing all the clearance light fixtures to sealed fixtures.
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 03-19-2013, 07:16 AM   #14
5wJoe's Avatar
DAISY BOYKIN: So I am going to ask a stupid question: Why replace working running lights with LED, when the power consumption occurs while the trailer is connected to the TV? I understand interior lights, but do not get the exterior light replacement.
5wJoe is offline   Reply With Quote
Old 03-19-2013, 07:22 AM   #15
KyDan's Avatar
LED replacements are typically much brighter.
Old 03-19-2013, 07:31 AM   #16
KyDan's Avatar
My clearance lights have a sort of O-ring around the white base that is
supposed to help seal the snap/push on red/amber cover.
Upon close inspection I discovered that they actually have a built in drain
notch on one side.
Guess what??
Apparently the morons who installed mine paid absolutely no attention
to this drain detail. About half of mine are mounted with the drain notch
UP and the rest with the notch facing Down
Since the notch is part of the base which is nicely caulked and screwed to
my trailer, turning the offending marker lights over would be a real PIA.
I've just left them as is for now. So far they have not filled up with
water but now that you mention it, I have a small leak in my rear bathroom
window. There are 3 marker lights above it. I better go check-- I bet that's
where the water is getting in and not the window itself.
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-38
Old 03-19-2013, 07:58 AM   #17
jriddering's Avatar
I was getting the bulb number on my running lights this weekend and when I took off one of the covers, it was dirty and you could tell water had been in it. I will check all my lights now.
Thanks for the heads up
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
Old 03-19-2013, 08:20 AM   #18
OL Creeker's Avatar
All the better to be seen
I finally received my led replacement bulbs for my running lights. So today
was a nice day here in Florida, no snow, no minus temps. It was a good day to put in my new LEDS.
First off I replaced the three light bulbs on each side of my beloved ROCKY 5Th wheel. Then I set out to replace the five rear red running light bulbs.
Here is where I discovered water had been in each and all five red lights on the rear. There was indications of the lights had been full all the way up to the top of three of the lights. The other two, only half way full up to the bulb socket. I guess the water could not go any higher for it was (water) draining into the rear wall through the light socket!!!!!!!! I hope not?
I cleaned all the rusty residue, replaced screws with new ones.
I drilled 1/16" hole in the bottom of the red lens in the center of the lens.
I also drilled a 1/16" hole in the light frame in the center bottom.
Caution, do not drill too close to the edge of the red lens for it will cause the lens to crack.
After replacing the lens, I applied silicone caulk to the top of the lens groove.
I will keep a close eye on the rear lights from now on for water leakage.
It is advisable to check your rear red running lights for water or signs of water has been in the lights,
Good LUCK!
I replaced mine a few months ago. Makes for a safer trip knowing my signals are more visible. To say nothing of the brake lights!
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 03-28-2013, 02:50 PM   #19
MikeInColo's Avatar
...was a nice day here in Florida, no snow, no minus temps.
I'm sorry but I couldn't get past the "no snow, no minus temps" remark.
We are talking Florida, right? Does it snow in some parts of Florida?
MikeInColo is offline   Reply With Quote
Old 03-28-2013, 03:12 PM   #20
QuietTimes's Avatar
Hi Sid - there was a thread the other day about riding in TT's while being pulled. Perhaps you can post those pictures there for those who thought it might be okay. Hope you fared well with insurance. I can't imagine what that felt like in the TV. Glad you were okay.
Heather & Jim
2012 Ford F150 EcoBoost
2013 Rockwood 2703WS
Days camped 2012 - 14 (not enough); Days camped 2013 - 41 (May - 3; June-16; July-10; Aug.-12) Still not enough...
Days camped 2014 - 23
QuietTimes is offline   Reply With Quote
