Old 03-08-2013, 02:31 PM   #1
DAISY BOYKIN's Avatar
I could not believe what I found!!
I finally received my led replacement bulbs for my running lights. So today
was a nice day here in Florida, no snow, no minus temps. It was a good day to put in my new LEDS.
First off I replaced the three light bulbs on each side of my beloved ROCKY 5Th wheel. Then I set out to replace the five rear red running light bulbs.
Here is where I discovered water had been in each and all five red lights on the rear. There was indications of the lights had been full all the way up to the top of three of the lights. The other two, only half way full up to the bulb socket. I guess the water could not go any higher for it was (water) draining into the rear wall through the light socket!!!!!!!! I hope not?
I cleaned all the rusty residue, replaced screws with new ones.
I drilled 1/16" hole in the bottom of the red lens in the center of the lens.
I also drilled a 1/16" hole in the light frame in the center bottom.
Caution, do not drill too close to the edge of the red lens for it will cause the lens to crack.
After replacing the lens, I applied silicone caulk to the top of the lens groove.
I will keep a close eye on the rear lights from now on for water leakage.
It is advisable to check your rear red running lights for water or signs of water has been in the lights,
Good LUCK!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 03-09-2013, 12:10 AM   #2
TURBS's Avatar
Was there not silicone around light bases to begin with?
Old 03-09-2013, 05:27 AM   #3
White caulking was applied-----------
Turbs, the only caulking or silicone that was on the lights was on the white base where they were attached to the rear wall.
The water got inside the lights where the top of the wall rolls down from the roof. The water drains down from the roof over the roll down to the white base of the lights. At this point the water makes its way into the light fixture where the red lens snaps to the white base.
Maybe some of the later towables has a flat rear wall to accommodate the arched newer roof. Mine is a Rockwood 2011 fifth wheel.
Old 03-09-2013, 07:02 AM   #4
Wanna Be Camper
SaskCampers's Avatar
Something I will be checking as soon as it gets a little warmer outside. I can see that being an issue for many units regardless of brand.
Thanks for the heads up.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 03-09-2013, 07:10 AM   #5
WolfWhistle's Avatar
Good LUCK!
Water can mess up lights, huh? You just reminded me to drill holes in the bottom of all my lens covers. I drill 1/8" hole with a sharp bit and let the weight of the drill do the pushing. It seems strange that water can come in through at the top and not drain out the bottom as fast. I have seen this in the past and keep forgetting to take care of it. Also, in the case of those of us with outside mounted batteries in plastic boxes, I have experienced water can come in through top vent holes and with no drain holes in the bottom of the box, fill the box with water. I store my TT under an RV carport, so this doesn't happen, but I will be sure that can't happen either, since I will be hosting soon and it will be outside alot.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 03-09-2013, 07:40 AM   #6
I prefer to melt holes in plastic, rather than drill. Much less chance of cracking. I just heat up a nail close to red hot, of whatever size hole I need. Quick, easy, and never have a crack.
bakken is offline   Reply With Quote
Old 03-09-2013, 01:08 PM   #7
Located replacement lights-----------
I broke one of my red lens by drilling a 1/8" hole too close to the edge. I tried three places before I found a replacement lens. WalMart does not have the right size, Auto zone does not have them, They can be found at Northern Tools for the exact whole light for $3.99.
I also replaced my tail lights with LED SUBMERSIBLE boat trailer lights. I also replaced the red lens screws with Stainless Screws.
The led lights appear to be 10X brighter than the original. I can really tell the difference when I apply my turn signal to change lanes as the traffic behind me seems to notice the brighter light, they are super bright!!!!!!!
Old 03-09-2013, 01:50 PM   #8
Director, FROG
F.R.O.G.'s Avatar
Sid, too bad you didn't have them before that idiot decided to park inside you trailer!
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 03-09-2013, 02:56 PM   #9
Would it have helped?
I don't think waterproof, no waterproof, 1000 lights would have made any
difference when the Expedition hit me!
Take a look and see what you think? Oh, he missed one of the lights! WOW, can't believe one light survived.
Believe it or not, a 1996 ford Expedition will fit inside a 26' Flagstaff, well almost.
No, he was not texting!
ID:	25277   Click image for larger version
Name:	OCT 1999 #2.jpg
ID:	25278   Click image for larger version
Name:	OCT 1999 #3.jpg
Old 03-09-2013, 03:01 PM   #10
Explorer
I pulled my light covers off and did find moister in the rear running lights, just a couple drops but something I'll have to watch.
YoungKopernik is offline   Reply With Quote
