Old 06-13-2013, 01:27 AM   #1
i have a 2012 grey wolf 29dsfb
I have lost the 12 system. There must be a master fuse or breaker I can't find. I can't slide in to take it to the dealer. Can you help me?
ghunt64 is offline   Reply With Quote
Old 06-13-2013, 06:21 AM   #2
TURBS's Avatar
Is the battery dead?
Slides can be brought in manually.
There's a possibility that there's a resetable circuit breaker by the positive battery cable.
Is your unit plugged in to shore power?
Need more info here.
Turbs
Old 06-13-2013, 06:59 AM   #3
Yes the battery is dead, and yes it is plugged in. I'm sure there must be a resettable breaker, but I cannot find it. The 15 amp 110 breaker was tripped to my gfci. When I reset the breaker, it tripped the gfci. I reset the gfci and now none of the 12 volt systems work. No radio, no lights, slide, stabilizers, even the front power jack doesn't work.
Its a 2012 Grey wolf 29dsfb
I don't know how to manually bring in the slides either.
Old 06-13-2013, 07:05 AM   #4
TURBS's Avatar
Can't you manually charge battery?
Old 06-13-2013, 07:11 AM   #5
TURBS's Avatar
Unless the the converter is bad or the breaker is tripped for converter the converter should be supplying 12v.
You didn't by chance reverse the battery cables on battery?
In this link you'll find how to trouble shoot your converter as long as you have a wfco. Which you probably do.
http://www.forestriverforums.com/for...hp?do=cat&id=6
Old 06-13-2013, 07:28 AM   #6
I'm headed back to look at it again this morning. I'm trying to charge the battery to see if that helps, but I'm concerned that the battery isn't charging from the 110.
Old 06-13-2013, 07:32 AM   #7
TURBS's Avatar
The link I supplied will show you how to check your converter/charger.
Old 06-21-2013, 10:45 PM   #8
Thanks for the help, Turbs. Turned out the converter was bad. We're back on the road again.
Old 06-22-2013, 01:02 AM   #9
TURBS's Avatar
Good deal.....
Its normally my Spiel to recommend NOT installing another wfco converter but rather a progressive dynamics brand but hopefully the second wfco lasts longer.
Turbs
