Old 01-28-2014, 12:55 PM   #21
bikendan's Avatar
i agree that the Champion 3500 would be perfect for your usage.
sells for around $300, has great customer support and is a well-proven unit and well loved for your type of need.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-28-2014, 10:16 PM   #22
Gregg Willow's Avatar
Originally Posted by ironj View Post
ive seen a 2000i start and run a 13k ac with hard start cap instlled and off of eco throttle.......it was working tho....
I have the 2 Honda 2000's. I can run my 13.5k with one of them. I start the fan first, then go to compressor. I do not have a hard-start. As mentioned, it's working. If I need A/C I use both in Eco mode. Much nicer on the ears and easier on the equipment.
A reply to an earlier post concerning the cost of a Honda, or a Yamaha for that matter, to just be used 2-3 times a year, I use my generators for more than just camping. My house does not have external outlets so I use one of the generators for running my electric smoker (up to 12 hours at a time), my buffer for waxing my vehicles, etc. Plenty of uses other than just camping. YMMV.
With that said, go with your whats available in your bank account. I believe you get what you pay for but there are some good alternatives at good price points.
2016 Ford F-150 4x4 Supercab XLT EcoBoost
2012 Salem Cruise Lite 221RBXL, Andersen No Sway WDH, (2) Honda EU2000i's
Gregg Willow is offline   Reply With Quote
Old 01-28-2014, 10:45 PM   #23
ironj's Avatar
a good lot of the newer ac have a start cap built in.....maybe not as large as a supco but it does make a diff......mine had nothing......
just out of curiousity how does your house not have a single outlet externally?...i have honestly never seen one that didnt? maybe its a texas thing.....when i built mine i had em put like 5 in the garage alone!!!!! lol...kegerator, compressor, extra fridge/freezer, drop lights, garage door openers....heck maybe i have more than 5!!
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 01-29-2014, 02:01 AM   #24
Just Creeking Around
Do yourself a favor. Spend the $$ on the Honda 2000I and the 2000I companion. You will pay for good, quite and proven gear. Depending on your needs you may only need the 2000I. Parallel the companion in and you have about 4000 watts. I have a 39 ft. Cedar Creek 5vr and the dual set up is my source when boondocking or state parks. You can add an external gas tank for long running times.
Jerry and Carol
Pahrump, Nevada
2014 38CK-Auto Levelers
2012 F350 Super Duty Crew, Air Bags, Pull-Rite Superglide, Splendee Combo.
F R O G, GS
Jerry L. is offline   Reply With Quote
Old 01-29-2014, 02:10 PM   #25
So...spend $2000+ on a pair of Hondas for a total of 4000W for 2-3X a year use. OR...spend $400 on a 4000W Champion. Hmmm...I'm no mathematician, but that doesn't pencil out to me. I agree...the Hondas are nice, but, I can buy 5 Champions over the next how many years if they wear out! Did I mention I only it 2-3X a YEAR!?
If I were going to use this genny a lot...I'd spend the Honda money. But $1500 difference for my needs at this point is just a waste.
Outlaw is offline   Reply With Quote
Old 01-29-2014, 02:22 PM   #26
Hey now,dont just think of yourself,buy the Hondas and (Loan) them out to other friends too use when your not using them! Justified Purchase! Youroo!!
Old 01-29-2014, 02:29 PM   #27
RPAspey's Avatar
And if there's a major storm or power outage, you could run a lot of items in your house.
2000 Cherokee 31BH, lifted,LEDs, solar, inverter, etc..aka "boondock ready". '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 01-29-2014, 03:17 PM   #28
DangerCliff's Avatar
Are you sure you need a generator? I can plug my RV into a 15 amp outlet with a adapter at my house and run 13,500 AC. No problem, hooked to a 20amp I can also run fridge and lights. If your friends have a outlet you could hook up to you might not need a gen. You might try hook up at you house and see what all you can run.
2013 Sunseeker 2860 Chevy
2014 Chevy Spark
Days Camped 2013 93.
Days Camped 2014. 89
DangerCliff is offline   Reply With Quote
Old 01-29-2014, 03:23 PM   #29
OUTLAW:
I think for your needs a champion would suit you just fine. For the amount of times you would use it and where it sounds like the perfect solution IMHO.
___________________________________
Salmon Hunter
2011 Crusader 320 RLT/ Honda 3000ei
2006 Chevy 2500HD 4x4 Crew Cab/Duramax Diesel/Allison Transmission
Salmon Hunter is offline   Reply With Quote
Old 01-29-2014, 03:48 PM   #30
Typically I pull the camper home on about Wed. before a camping weekend to load the clothes & food. I plug the shoreline (with adapter) into my 110 garage outlet to start the fridge cooling for food for the weekend.
I've tried kicking on the air...the fan will blow but AC compressor will not kick in!? I was told that it is most likely because my garage outlets are 15A w/ GFI that is probably preventing AC startup!?
Even if your idea of plugging into my friends house DID work...DON'T YOU DARE TELL MY WIFE! This is one way for me to justify getting a generator to power my ice fishing shanty too (year-round use)!
generator
