Old 02-22-2016, 06:41 PM   #1
I think I killed My Battery
Today I Found my battery completely dead, like zero volts. I go out to the storage lot once a month in November, December, January and February and plug the camper in to my truck generator for an hour or so and check everything out. We usually camp a couple of weeks a month the rest of the year so the battery stays up. Looks like I somehow left the little light on the power tongue jack on. I have the battery on a charger in my garage now. Hopefully it comes back. It is only 2 years old.
beachcamper is offline   Reply With Quote
Old 02-22-2016, 06:59 PM   #2
Flybob's Avatar
If you killed it to Zero ( actually anything below about 9V) it is unlikely the battery will recover. It may take an apparent charge, but as soon as you put any load on it, it will die.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 02-22-2016, 07:06 PM   #3
I guess I'll leave it on the charger overnight and have it load tested in the morning at autozone or advance auto parts then.
Old 02-22-2016, 07:52 PM   #4
Moderators' Assistant
bikendan's Avatar
Why don't you just install a battery disconnect switch?
I have one and my two batteries were still nearly fully charged, after 4 months in the storage lot.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 02-22-2016, 08:21 PM   #5
fast murray's Avatar
How hard is it to take the battery out for the winter? Beats the heck out of hanging out for an hour every month charging it.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 02-22-2016, 08:31 PM   #6
VinceU's Avatar
Since you regularly "short charge" the battery and allowed it to discharge way beyond the normal 50% of full charge, without a doubt some plate damage has occurred. You can expect near full voltage to return however current capacity will be reduced 30-50 % of original. If the acid was reduced to water, and froze, damage could be much worse.
Easy to remove unbolt two cable connections, remove hold down strap. Remove neg post first.
Old 02-22-2016, 08:43 PM   #7
I used to disconnect the battery on my old camper. This new 8329ss has a disconnect switch. Disconnects everything but the jack. Battery on my old camper lasted 6 years.
Old 02-22-2016, 10:02 PM   #8
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
Although I am fully solar powered and never worry about keeping the bats up, I have a 4-way disconnect switch for the two house batteries. No disconnecting, hauling around 70+ lb bats, getting dirty, just flip the switch to off and forget about it. Cheap fix and easy to install. It has been the first mod on every RV I've owned.
My two house batteries are not outside, but under a hood that raises up to get to the batteries and 2 x 30lb gas tanks. The switches can be reached by reaching under the hood and not having to open it. Can't get any easier than that.
If your batteries are in outside boxes, you can mount the disconnect switch directly on the side of the battery box.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 02-22-2016, 11:09 PM   #9
MNtraveler's Avatar
Every 2 weeks for 2 hours, or plug the unit in for a day or two, or take the batteries out and put them on a tender that knows how to slow down to a float charge.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 02-23-2016, 08:34 AM   #10
Herk7769's Avatar
A 4 stage battery charger may save that battery.
The 4th stage is a desulphate mode that pulse blasts high voltage into the plates that forces sulphates built up on the plates back into solution as Sulphuric Acid.
I had a "dead-dead" pair of truck batteries from my diesel prime mover die two winters ago. I replaced both with new ones and put the 2 dead ones on the battery charger. One came back almost good as new; the other was toast and turned in for core.
HAM CALLSIGN - KC3FFW
battery, led
