Old 07-16-2014, 05:42 AM   #11
sail2liv's Avatar
I use the champion 4000, and it starts and runs the a/c, but after hooking the surge protector to it and seeing that cycle between normal and then reverse polarity, I do not run 15000 a/c on it.....if I don t have a campsite with power I wait till seasonal temps are okay to go to that area....is always Blue Ridge Pkwy in Aug.....that way do not need a/c.....and Gulf States in winter.....good luck.....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 07-16-2014, 05:45 AM   #12
BamaBob's Avatar
Originally Posted by OutlawAdventurer View Post
I have a 3000 watt honda, just sold it, I have run my A/C...and a few other items in our toy hauler at the same time....a lot depends on the draw......there is a chart that you can download on internet with each appliance draw, give you an idea of the load with each one on.....(cant remember the webpage),
Truthfully though when we are out by our lonesome, I use the 8500 watt...it powers everything....
Actually...the Honda (and Yamaha) gennies are made to run in parallel - specifically for this type of application. You run 2 in parallel (special harness and special second gennie) for when you need A/C. Run only one when all you need is lights, TV and (I think) a microwave.
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-16-2014, 05:46 AM   #13
BamaBob's Avatar
Hmmm I gotta read the thread all the way through before replying LOL...shoulda just said X6
Old 07-16-2014, 10:42 AM   #14
TigerPride
cajunrvr's Avatar
Like has been said manage ur power we used a honda 3000 for four days had our ac(15k) all the lights(led) and mini fridge outside all running off honda big fridge and hot water ran off propane. Could not run it on economy when ac would crank up the idle speed on honda would not rise fast enough to handle the load. We just ran it wide open the whole time it used 5 gals/24hrs and still quieter than any other gen that was out there
06' f-150 5.4L
2015 rockwood 8286ws
Diamond package
cajunrvr is offline   Reply With Quote
Old 07-16-2014, 11:07 AM   #15
What's nice about the tandem generators is that they're very quiet, and they're very efficient. Run just lights and a few items, and you can get by on one generator. Crank up the air conditioning and you run'em both.
Another good thing is that they're easily moved without wheels @ 46 lbs.. Down side is that they're so portable that they're high theft items. Honda even sells a steel handle that allows you to chain them to trees, etc. for security purposes.
I'd be just as happy with their EU3000 unit, and at 78 lbs. it can be lifted out of the "basement" and rolled away from the camper.
Bamaman is offline   Reply With Quote
Old 07-27-2014, 10:20 AM   #16
We just bought our first TT. It's a 2014 Wildcat 185br. The fridge is electric only. Would the Honda 2000 be sufficient to run the fridge, lights and either the a/c OR a hair dryer?
Thanks!
2014 Wildwood x-lite 185br
towed by 2013 Ram 1500
laurarice26 is offline   Reply With Quote
Old 07-27-2014, 10:23 AM   #17
Dennis and Julie's Avatar
Thanks!
No you would need 2 eu2000 running in tandem.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 07-27-2014, 01:18 PM   #18
I run two Honda eu2000s to run everything in my 30 amp TT, including my 15000 A/C unit. I believe the constant output for the pair in parallel is 3600 watts or 32 amps, although it can surge for brief periods to higher output.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 07-29-2014, 08:40 AM   #19
I use a Lifan energy storm 3600 inverter-generator. Runs the 15kBTU AC just fine.
larryscsi is offline   Reply With Quote
Old 07-29-2014, 08:53 AM   #20
Gregg Willow's Avatar
That would be the EU3000i Handi for that weight. The EU3000i is about 165 lbs dry.
2016 Ford F-150 4x4 Supercab XLT EcoBoost
2012 Salem Cruise Lite 221RBXL, Andersen No Sway WDH, (2) Honda EU2000i's
Gregg Willow is offline   Reply With Quote
generator
