Old 03-22-2014, 10:37 AM   #41
Originally Posted by jwedell View Post
The GFCI outlet has a line and a load side if it's wired backwards it will not work. If you can use a volt meter to check it out.
The GFCI outlet has a small green light on it that shines when the outlet has been wired correctly per the instructions it came with...my green light is shining
33zkine is offline   Reply With Quote
Old 03-22-2014, 10:43 AM   #42
OK
jwedell is offline   Reply With Quote
Old 03-22-2014, 05:31 PM   #43
All fixed!...The new GFCI Outlet I installed was defective...exchanged for a another "new" GFCI Outlet installing it and a new Breaker switch as well...Viola! Thank You everyone for the info and for all your Help!...all of you who responded and helped me with troubleshooting Rock!...I've posted pics of the Trailer that was in Question...Thought I would post pics of it before I put it back together...try not to mind the mess I've made...So relieved...
Name:	rockwood trailer 1.jpg
ID:	48174   Click image for larger version
Name:	rockwood trailer 2.jpg
ID:	48175   Click image for larger version
Name:	rockwood trailer 3.jpg
ID:	48176   Click image for larger version
Name:	rockwood trailer 4.jpg
Old 03-22-2014, 08:21 PM   #44
Good job and an excellent learning experience.
Old 03-22-2014, 08:46 PM   #45
Flagstaffer06's Avatar
Awesome, glad it all worked out! I never leave for a trip without my voltmeter, it's a must have for troubleshooting.
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 03-22-2014, 09:01 PM   #46
caper's Avatar
Glad to hear all worked out.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-22-2014, 10:46 PM   #47
beerjay's Avatar
Glad you got it all fixed, now you can enjoy camping this year!
Our trailer is coming out of storage in April but we just got another foot of snow and its -15C. Still a bit chilly!
2009 Suburban LT 1500 - 4x4 - 3.42
2009 Flagstaff 23FBS Super Lite
Nights Camped in 2015 - 21
Nights Camped in 2014 - 29
Nights Camped in 2013 - 31
beerjay is offline   Reply With Quote
Old 03-23-2014, 07:53 AM   #48
PhoneDude 8289's Avatar
Got a new RV and so far no real trouble with it. Couldn't get cable tv to work, removed the amplifier from the wall and found it was wired wrong. On our shake down trip from Florida to Texas I decided to check everything I could. Started at the battery disconnect, one terminal was very lose, tightened it. Opened up the electrical panel and checked every screw, several connections there were not tight at all. The grounding bar in the panel had several connections that were not tight, snug but not tight. Got into the converter and found the same thing, terminals not screwed down tight at all. At some point a single lose connection could cause some real problems, glad I checked.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 03-23-2014, 07:55 AM   #49
VinceU's Avatar
Not fair! We'll never know if was brkr or outlet? Who cares....it works...
electric, electrical, rockwood
