Old 06-17-2015, 12:12 PM   #1
brer_rabbit10's Avatar
Incoming voltage
I'm taking delivery of a new 5th wheel Friday, without a generator. I see that Honda has a technique where two generators of the same model can be joined to be able to access double their individual output. I thought this might be a cost effective alternative to a single, built-in Onan. I could take one out and use it by itself or put it back, join the two together and I could have as much amperage as I need (obviously, within reason). They even have a wireless remote start capability. My my concern is voltage. When I plug into a 50-amp service at a campground am I getting 120 or 220 volts? When I talk to the Honda sales rep I really need to have the correct information.
Bill Case
Silverback 35QB4
F350 Diesel prime mover
brer_rabbit10 is offline   Reply With Quote
Old 06-17-2015, 12:25 PM   #2
Boss Ox & Drovergirl
oxcamper's Avatar
I believe you get 2 - 120V legs.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 06-17-2015, 12:35 PM   #3
TURBS's Avatar
Yes your plugged into 2 individual 120v 50a legs.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-17-2015, 12:40 PM   #4
WolfWhistle's Avatar
You can get the Onan 4K for $2800 delivered. The hondas will about $2000 (the pair) plus roughly $40 cable. One of these should be the 2000i companion model. You can get an off brand 4K generator for considerably less than even one Honda. There are obviously advantages to each method; whether it is price, flexibility, or convenience you are after. The Onan is made for continuous duty, where the off brands are not. So, it also depends on how long you expect to run it. A portable genny can be used all around the home or farm, where the Onan is primarily for the camper, as you mentioned. However, the reason I didn't opt for the Onan is the extreme noise and vibration it produces in the bedroom area that it is adjacent to. You might not have that problem with your's.
CG 50 Amp service is two (2) 120 volt circuits with 50 amp breakers on each (x2). The other option is 30 amp service (x1). In both cases your unit is only using 120 volts; never 240v.
When 30 Amp is all you can get, you can adapt your 50 amp cord to 30 amp, but as you can see you will have less than 1/3 the current capacity as you would from the 50 amp. The Onan 4K will give you slightly over 30 amp, which would let you run one AC unit at a time. Same for the pair of Hondas. It is possible to run your unit on these, but will require careful, manual, power management. A 50 amp generator is also available. I would think these are in the range of 5500 watt units or higher. That would be a single large Honda, not a pair of them. These large genny's get very heavy, needless to say.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 06-18-2015, 06:44 AM   #5
Herk7769's Avatar
The two Hondas will NOT power both legs of your 50 amp service (6,000 Watts per leg or 12,000 watts total).
You will need FOUR hondas (not two) to provide 4000 watts (peak power) to each leg of your 50 amp service.
Two Hondas will provide the same level of power that a 30 amp single leg pedestal will provide (3600 watts continuous).
A 50 amp service camper will need a generator capable of outputting 220 volts (120 volts on each leg with neutral) in order to power all your items.
HAM CALLSIGN - KC3FFW
voltage
