Old 10-10-2016, 11:30 AM   #1
Inside lights
We have a 2016 Silverback 29 RE. The inside house lights do not work or the basement lights, when on the battery only. There does not seem to be any power to the 12v side of the fuse box. When plugged into shore power everything works fine. I found a 30A fuse from positive post on battery under the front basement door, it was not blown. It does run to a small box (relay?) on the wall. Is there another main 12v fuse that would supply the 12v side of the fuse panel somewhere?
shadetree is offline   Reply With Quote
Old 10-10-2016, 11:32 AM   #2
SeaDog's Avatar
I don't know your model of rig but could it be that your battery disconnect (if you have one) may be in the disconnected position
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 10-10-2016, 11:37 AM   #3
Checked Battery switch, it is on. Cedar Creek Silverback.
Old 10-10-2016, 01:36 PM   #4
Does the "relay" look something like this?
If it does, it is a circuit breaker. Look for a small button on it, push to reset.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 10-11-2016, 11:29 AM   #5
I'm not near it to take a picture, but it isn't a circuit breaker. It has one 10ga wire with a 30 amp fuse going to it, and 3 smaller wires coming out of it. It probably doesn't have anything to do with my problem, lol. That was the biggest wire coming off of the positive bus bar coming from the battery. I just thought it might be the problem because of that. Thanks!
light
