Old 03-18-2016, 05:58 PM   #1
Inside lights, 27rr
Hello all, I have a 27rr greywolf. The inside lights have the dimple in the center of the hockey puck style light that you gently push to turn off/on. Seems like on a couple of them the switch is out of place, so the light won't turn on/off. Is it easy to take the light apart y
To adjust the switch? Thanks all
Clay1206 is offline   Reply With Quote
Old 03-18-2016, 06:03 PM   #2
SeaDog's Avatar
Most of the lights in TT are easy to take apart as to adjusting the switch I cannot speak to that. pop the lens and look for the mounting screws and remove the light should come free of the ceiling. You will then need to remove the wire nut the mfg installed which is normally a crimp fitting and when you put it back together use a screw on wire nut. good luck
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 03-18-2016, 06:58 PM   #3
Just pry the lense off with a screw driver?
Old 03-18-2016, 07:01 PM   #4
rmac04401's Avatar
Once you take the cover off you should be able to line up the switch again. I had to do this on my 26 rr.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
light
